B16a head on b18c1 block w/ ITR rods and pistons
Will there be any performance gains? I know ill have to change the ecu but will there be any noticable differences in it vs the gsr head? Please give me more information...
isnt the b16a head from the same cast as a type R? The type R head uses a different valve train and manifold and has a p/p.
I gotta comment on this.
Honestly for flow on the last third of the tach the single stage is better. But the GSR intake gives you a flatter curve, meaning that your car will feel faster around town when not banging off the limiter. Don't even look at what all the 500+ whp guys are running you don't need all that flow.
But if you are using a B16 head you can't easily bolt up the GSR manifold anyway.
I don't know all the math but the B16 has a larger combustion chamber, so you will probably be losing some compression, even with the ITR piston.
[Modified by eh-D, 6:31 AM 12/23/2001]
If you want to go single runner then jst get a Skunk2 manifold and run a GSR head. I remember reading somewhere that the ITR head flows best then GSR then the B16 heads.
GSR heads are good but have a handicap due to smaller combustion chamber, meaning less volume than an ITR or B16 head. The smaller chamber means more compression. GSR heads have .3 higher compression with the same pistons as an ITR or b16 head (based on a b18c bottom end). PR3 heads allow more volume.
Guest
Posts: n/a
The ITR head get's ligher valves, dual valve springs, and a mild port and polish.
