damit JIM !! Stripped a Frezze plug on the block???
Old Nov 3, 2004 | 05:09 PM
TurboB18C1's Avatar
Default damit JIM !! Stripped a Frezze plug on the block???
Installing a ENDYN Catch Can ... from underneeth the car until one of the plugs stripped i removed the intake manifold and then realized i should of done this in the first place.... anyeways here is my problem
i was trying to take the frezze plug out from the rear part of the block and the next thing i knew it stripped .. FU*& this really sucks i tried a small pipe wrench and also bigger allens and nothing seems to grabbing... it... so i was wondering if anyone could ellobrate on this... thank you...
Old Nov 3, 2004 | 05:20 PM
drdisco69's Avatar
Default Re: damit JIM !! Stripped a Frezze plug on the block??? (TurboB18C1)
If it's really stripped, and it probably is, prepare the drill. Put a hole in it and use a screw extractor. It's a pain in the ***, but works.
If there is any part of the plug sticking out, try vice grips. Sometimes they can save the day.
Old Nov 3, 2004 | 05:33 PM
No-Gi's Avatar
Default Re: damit JIM !! Stripped a Frezze plug on the block??? (drdisco69)
Chisel that bitch loose, but be careful.
Old Nov 3, 2004 | 08:16 PM
HONDA_TYPE_R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">If it's really stripped, and it probably is, prepare the drill. Put a hole in it and use a screw extractor. It's a pain in the ***, but works.
If there is any part of the plug sticking out, try vice grips. Sometimes they can save the day.</TD></TR></TABLE>
DO WHAT HE SAID!!! Not to dis on the chisel, but I know how I get when something is frustrating, and me with a chisel and hammer is a VERY BAD IDEA. I sadly break things because somewhere in my head I believe that force solves problems...at any rate, not saying you have a bad temper, but I think drilling and using a screw extractor would do you a lot of good. Vise Grips are also a great way to remove stubborn ****...you better get a new plug esp. if you use these.
digital sol
Welding / Fabrication
Jun 26, 2007 10:35 AM
TylerB
13
Apr 23, 2006 03:58 PM
bigcheese42
Mar 9, 2006 01:17 PM
