wheel-hop solutions for road racing/drag double duty
If you road race/auto-x and drag race your car, what is the best solution for wheel-hop? I am considering motor mount inserts or radius arms (connect to LCA's). Mainly I was wondering what effect the radius arms will have on handling.
Not knowing what car your driving.......
Lower tire pressures for drag racing, 22-24 on street tires.
This helps the most for being free.
The motor mount inserts helped a little, but I am running drag slicks at 14 psi.
Never missed a shift with just the rear insert. If you put all the motor mount inserts in, your dentist will love you.
we have quite a few guys running radius arms for both. in both drag racing and roadracing/auto X Lca deflection is a problem
