Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Race Blocks, Sleeved, fully built, Race ready by Exospeed Race Engines
Old Nov 3, 2004 | 03:15 PM
ExospeedAMcrx's Avatar
Default Race Blocks, Sleeved, fully built, Race ready by Exospeed Race Engines
NO GIMMICKS! NO DISCOUNT COUPONS!
Just plain ol' quality professional engine build.
Limited Time Special from Exospeed Race Engines
Downtime on your race/street car? This is the perfect time to build the block.
Complete RACE ENGINES built in-house... Professional Honda Specialist
B-series Street/Race Specials
Exospeed Race Engines Stage 4 Race Block
reduced from $2800.00 to $2595.00 and with shipping included back to you.
Exospeed Sleeved block
Arias Pistons 81.5mm or 84mm with piston rings
Compression 9:1
Eagle Rods with ARP bolts
Honda OEM Bearings: rod and mains
Honda OEM Bottom end gasket kit; Oil pan gasket, oil pickup gasket, main seals.
Honda OEM Oil pump
Bore and Hone with clearances for Arias pistons
Hot tank
Step Deck
Labor: Measure bearings
Labor: Assembly
Core Required
Note: Keep in mind this is the same blocks we use on our race cars. No ACL bearings here. All Genuine Honda bearings measured to spec for each crank/block. So your crank will turn like Butter.
Some of our measuring tools to measure bearing clearances and assembly lube that we use.
Race cars running these Exospeed Stage 4 race blocks.
600-800 HP Race engines!!!
Eric Del Rosario: NHRA Hot Rod Class
Irran Jolly: NHRA Hot Rod class
Cortney Green: Sport FWD Exospeed Sleeved Block 10.1 street car.
and many more street cars
This winter special has been extended until Mid January.
Full payment is not necessary. Deposits are encouraged to take advantage of this special deal. We know that some engine build projects are often long term and we can accommodate the build to your needs.
B18A/B cores are available. Block and Crank combos.
D and H -series available also. Contact us for special pricing and compression choices.
Modified by exospeedAMcrx at 5:06 PM 11/10/2004
Modified by exospeedAMcrx at 1:53 PM 12/13/2004
Modified by exospeedAMcrx at 10:07 AM 4/1/2005
Old Nov 3, 2004 | 04:07 PM
11psiTurboSI's Avatar
Default Re: Race Blocks, Sleeved, fully built, Race ready by Exospeed Race Engines (exospeedAMcrx)
Nice Price
Old Nov 3, 2004 | 04:31 PM
Default Re: Race Blocks, Sleeved, fully built, Race ready by Exospeed Race Engines (9psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">Nice Price </TD></TR></TABLE>
Not only a good price, but using top notch parts. Assembly by one of the best engine builders in the business.
Old Nov 3, 2004 | 06:32 PM
What kind of sleeves do you use?
Old Nov 4, 2004 | 02:28 AM
Turbo88hatch's Avatar
One of the best companies I've ever delt with! Wil is always straight up, and will go out of his way to help you out. Nobody is touching my motor other than Wil and the guys at Exospeed. Top notch price, outstanding service, and a knowledgable staff
Old Nov 4, 2004 | 01:30 PM
we have our own Exospeed Sleeves and we use Darton as well.
We supplied plenty of Sleeving companies including RS Machines.
Old Nov 5, 2004 | 10:07 AM
Full payment not needed. We can get you in on our payment plan to get your block started. Contact us for details if you arent familiar with it.
Old Nov 6, 2004 | 06:05 PM
sillydrifter's Avatar
what is the price on a rebuild for a block. heres what i need. bores need to be checked for right size piston and rebored if needed. block has already been sleeved once by benson. need cp piston(9 :0.1)with rings gap and piston to wall clearences bored out according to specs from cp manufacture for turbo. i also would like to replace all bearing and seals. the oil pump should still be good. the block needs to also cleaned. email me back at saoher@comcast.net
Old Nov 6, 2004 | 06:43 PM
KENetics1's Avatar
could you pm me an estimate on a sleeved d16 77mm block with custom 10:1 comp. arias pistons. Along with the rest of the goodies on the list above.
Old Nov 8, 2004 | 12:55 AM
sly_106's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Compression 9:1
are these the only CR/bore sizes available?
Old Nov 8, 2004 | 10:36 AM
check PMs.
there are other bore and compressions too. you have a bore size in mind?
Old Nov 10, 2004 | 04:03 PM
your welcome.
Old Nov 12, 2004 | 05:25 PM
Anyone in Southern Cali, visit us at the IDRC event in LACR - Palmdale, CA on Sat and Sun Nov 13/14.
Our race cars will be there and will be able to answer any of your tech questions about our engines.
Old Nov 15, 2004 | 05:07 PM
Exospeed Race Engines represented at IDRC! Glad to have met some locals at the event.
Old Nov 16, 2004 | 05:55 PM
Thanks for all the calls today. you know we're down to do H22, F series, etc. call us!
Old Nov 17, 2004 | 10:34 AM
h22a193's Avatar
Default Re: (exospeedAMcrx)
Ok If yu can do 2500 for all of the things included above, and can get it done asap, then you may have my business. Where are you located?
Old Nov 17, 2004 | 10:40 AM
we can do it ASAP if you need it done right away. but I cant do it for $2500.00 the discounted price is already. $2595.00
We believe thats already a fair price for the quality of work that we do.
We are in Southern California.
Old Nov 17, 2004 | 10:41 AM
h22a193's Avatar
Default Re: (h22a193)
so I ship out my block to you and you do all the work, including assembly, and when I get it back its pretty much ready to go in the car? Evrything torqued and checked already, If you can guarntee this, and somehow warantee your work, and you get it to me for 2500 then you may just have yourself a deal.
h22a193's Avatar
email me at skylinegtrpro@aol.com
Old Nov 17, 2004 | 10:48 AM
If interested, PM me your number so I can call you so we can discuss details.
Old Nov 18, 2004 | 10:09 AM
indomotor's Avatar
You guys always have the best combo
Old Nov 18, 2004 | 12:51 PM
Jason kiDD's Avatar
Juss charge him $200 for shipping..
Old Nov 18, 2004 | 01:13 PM
Default Re: (indomotor)
thanks indo.
you know we do our best and only use the best parts.
Old Nov 18, 2004 | 06:25 PM
bossman032's Avatar
I wanna hit the nos
Old Nov 19, 2004 | 09:20 AM
nos setups are doable too
