How to install throttle cable (searched)
Old Nov 3, 2004 | 03:06 PM
s0ulless's Avatar
Default How to install throttle cable (searched)
Hey guys,
I'm installing a integra tb cable wire..and I'm just a bit clueless how it's suppose to be removed and installed. I'm doing this tonight to get my car up and going for the meantime until i fix the idle problem. Does the cable actually goes right into that rubber peice in the firewall straight to the gas pedal? or is there something I'm missing. I do not have a manual so all help is appreicated.
Thanks!
Prefer instruction..pictures would be even better.
Old Nov 4, 2004 | 07:13 AM
s0ulless's Avatar
Default Re: How to install throttle cable (s0ulless)
bummpp right back up
Old Nov 4, 2004 | 07:15 AM
Prod's Avatar
climb under your dash and disconnect one end from the gas pedal, then twist that plug out of the firewall, thats it
Old Nov 4, 2004 | 08:15 AM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s0ulless &raquo;</TD></TR><TR><TD CLASS="quote">
Prefer instruction..pictures would be even better. </TD></TR></TABLE>
A good reason to buy a Helms.
If you'd crawl under there and look at it you should be able to figure it out... it's not complicated.
Old Nov 4, 2004 | 11:20 AM
s0ulless's Avatar
Default Re: How to install throttle cable (JeffS)
thxs guys..I wasn't sure if that was the proper way to do it. Well, yea I just got an eletrontic version..sure is a pain in the a$$ to dig in those pages..PDF.. Printing out that 1000+ pages soo n.
THE GREEN CRX//
Feb 12, 2011 01:18 PM
pmey
Dec 2, 2008 01:30 PM
DOHC Kid
May 5, 2008 04:25 PM
efyou
Apr 28, 2006 09:40 AM
yeegsr
Nov 15, 2004 07:38 AM
