High compression with JRSC... is this okay?
Old Nov 3, 2004 | 02:45 PM
revvin9k's Avatar
Default High compression with JRSC... is this okay?
Well i am planning on ripping my motor apart again since I have an oil burning problem. Anyway, I have a b18c-r and was wondering if I changed out my pistons to CTR one(to boost the compression up a bit) will it be okay to put a JRSC on it? Thanks.
Old Nov 3, 2004 | 02:56 PM
pwrofdrm's Avatar
Default Re: High compression with JRSC... is this okay? (S(J)O(D)L(M))
Possible? Yes of course. Reliable? Well with high octane fuel, low boost, and LOTS of good tuning than yes. Probably produce pretty good numbers, as well.
IMHO though, if you're looking to go with a supercharger, look into Vortech systems. Centrifugal > Roots type blowers IMO
Old Nov 3, 2004 | 03:12 PM
Bbasso's Avatar
Default Re: High compression with JRSC... is this okay? (lax1185)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 &raquo;</TD></TR><TR><TD CLASS="quote">Possible? Yes of course. Reliable? Well with high octane fuel, low boost, and LOTS of good tuning than yes. Probably produce pretty good numbers, as well.
IMHO though, if you're looking to go with a supercharger, look into Vortech systems. Centrifugal &gt; Roots type blowers IMO</TD></TR></TABLE>
h Boy...:
Old Nov 3, 2004 | 04:22 PM
revvin9k's Avatar
My question is if it is safe. I will get it tuned of course, but can I throw in the CTR pistons in and run a 12.0:1 compression and then bolt on thr JRSC for the ITR and not have problems?
Old Nov 3, 2004 | 04:25 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) &raquo;</TD></TR><TR><TD CLASS="quote">My question is if it is safe. I will get it tuned of course, but can I throw in the CTR pistons in and run a 12.0:1 compression and then bolt on thr JRSC for the ITR and not have problems?</TD></TR></TABLE>
Why in the world would you do that? ITR's stock compression is already almost too high for boosting on pump gas.
-Chris
Old Nov 3, 2004 | 04:29 PM
revvin9k's Avatar
Default Re: High compression with JRSC... is this okay? (ccfries)
Should I not attempt this then and go another route?
Old Nov 3, 2004 | 05:17 PM
Stunna BEN's Avatar
Don't call it a comeback
High compression and boost!
Old Nov 3, 2004 | 05:31 PM
revvin9k's Avatar
Default Re: High compression with JRSC... is this okay? (.Ben)
Is it safe?
Old Nov 3, 2004 | 05:38 PM
Stunna BEN's Avatar
Management is key...
At the same time, not tryin to beat a dead horse, all it will be doing is spending money that isnt needed to be spent. Look on SGT's site some at the power made from some of these all motor setups.
Youll be much happier IMO.
Stunna- Whos b18c1 kaa used to love testing cars with the jackson...
Old Nov 3, 2004 | 05:59 PM
revvin9k's Avatar
So as long as it is tuned correctlly I should'nt run into problems? Thanks.
Old Nov 3, 2004 | 06:06 PM
Stunna BEN's Avatar
Not exactly. With a JRSC you have very high heat levels. Do more research b4 you do this, please.
Old Nov 3, 2004 | 06:29 PM
Justin Klemgold's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris</TD></TR></TABLE>
You're wrong. Dead Wrong. All it leaves is less error space for tuning. That's it. Take it to a good tuner and don't do a half *** tune and you will be fine. There is NO need to lower compression...that is an old myth that needs to die. It's been proven to be wrong many times. Just let it go.
Old Nov 3, 2004 | 06:33 PM
machgo5go's Avatar
Kaboom! look what happened to #0688.
Old Nov 3, 2004 | 06:35 PM
Batoutahell's Avatar
So far there have been 3 responses that are equivalent to talking out of one's ***. If you can't tell which 3 are the bs posts, then you need to step back and research the issue yourself before inviting every village idiot to give you his opinion.
Edit: While I was posting this, #4 reared its head.
Old Nov 3, 2004 | 06:48 PM
Seedc2's Avatar
Default Re: High compression with JRSC... is this okay? (Batoutahell)
is the vortech supercharger carb legal like the jrsc?
Old Nov 3, 2004 | 07:01 PM
Azcheron's Avatar
Default Re: High compression with JRSC... is this okay? (sim shadeee)
i have the JRSC on my ITR
at 5.5 psi on STOCK compression, i get detonation
CTR pistons will **** your car right in the ***, hard!
if you want to know more about the JRSC on an ITR, i have experienced it all and realize what needs to be done and how to do it
it is WAY more involved than you even know
Old Nov 3, 2004 | 07:10 PM
revvin9k's Avatar
Default Re: High compression with JRSC... is this okay? (Azcheron)
What recommendations do you have before I do this. Thanx.
Old Nov 3, 2004 | 07:17 PM
Azcheron's Avatar
what kind of boost do you want to run?
what mods do you currently have?
Old Nov 3, 2004 | 07:19 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) &raquo;</TD></TR><TR><TD CLASS="quote">What recommendations do you have before I do this. Thanx.</TD></TR></TABLE>
Don't do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">You're wrong. Dead Wrong. All it leaves is less error space for tuning. That's it. Take it to a good tuner and don't do a half *** tune and you will be fine. There is NO need to lower compression...that is an old myth that needs to die. </TD></TR></TABLE>
Well, right, there is NO need to lower compression. I run 10 PSI with stock 10.5:1 compression.
But why run 12:1? Seems like a waste of time and unnecessary risk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">It's been proven to be wrong many times. Just let it go.</TD></TR></TABLE>
I don't know many people running higher than 11:1 compression with boost. Not sure it's been 'proven many times'.
-Chris
Old Nov 3, 2004 | 07:26 PM
revvin9k's Avatar
I have 96 ITR with Spoon rods and pistons, Skunk2 valvetrain with stock ITR camshafts, Toda header.... nothing to wild. Just wanted to know if this was possible is all.
Old Nov 3, 2004 | 07:30 PM
-Chris
Why 12:1? A few reasons...
-More power
-Better low end (when you're not in boost which, in turn, makes it a much more feasible daily driver
-Why not 12:1?
The reason you don't see many people running 12:1 is because of thinking like yours (no offense man). People like to hold onto old myths and they like to listen to Honda "tuners" who really aren't knowledgeable.
Old Nov 3, 2004 | 07:32 PM
Chris F's Avatar
It probably is OK... but if I was starting from scratch, I'd leave the compression stock.
-Chris
Old Nov 3, 2004 | 07:37 PM
revvin9k's Avatar
I'll keep you guys updated with the project. Im going to try it.
Old Nov 3, 2004 | 07:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">It probably is OK... but if I was starting from scratch, I'd leave the compression stock.
-Chris
I agree. I would never lower it though. It makes off boost driving more of a challenge.
I would sooner raise my compression than lower it if I were going to boost but maybe that's just me. *shrugs*
Old Nov 3, 2004 | 07:50 PM
Chris F's Avatar
Default Re: High compression with JRSC... is this okay? (Justin Klemgold)
-Why not 12:1?
Diminishing returns.. at .5 bar the effective CR would be 18:1. Not many n/a guys are running 13+:1 on pump gas, let alone 15 or 18:1.
Your motor will be more efficient, but you can only compress gasoline and air so much before it ignites itself on any little hot spot you have inside the combustion chamber. Not only is it more volatile at high pressure but it will get hotter as you compress it.
Good luck with the project. I would highly recommend tuning to control both fuel and timing (i.e. Hondata or equivalent). King Motorsports and Whip Factory are two good tuners in the area that do Hondata.
