SKunk2 Manifold vs JG mani--- b16a2
Ok, I tried a search...and nothing came up that quite answered my question. I recently got a b16a2 swapped hatch, and it has the skunk2 mani on it. I was wondering which was better in the long run...under boost. I am boosting this winter, and didn't know if it would be better to stay with skunk..or change....
any help??
any help??
How much boost are you running? On a normal street or street/strip, you're probably better off w/the s2 (good mid-range- works good w/boost) - the JG manifold is great for high boost, high-revving engines.... You'll get better peak power w/the JG most likely, but the s2 will really help mid-range. -- What is your 'setup'?
b16a2
Skunk2 IM
T3/T4 turbo
Revhard manifold
3inch DP
3 inch echaust
RC 550
aem underdrive pulls
aem cam gears
stock internals
hondata s200 w/boost
Stock internals....planning on running 8-9psi
Skunk2 IM
T3/T4 turbo
Revhard manifold
3inch DP
3 inch echaust
RC 550
aem cam gears
stock internals
