rising of temp. close to over heating
Old Nov 3, 2004 | 01:07 PM
LISTO~'s Avatar
Default rising of temp. close to over heating
my accord seems to be running hot these days. its a 95 with 170k.
ive flushed and refilled with new antifreeze, new oil and new airfilter. car is STOCK. no leaks to be found, but temp still goes up often. what could be the problem/what could i check for?
thanks for the help
Old Nov 3, 2004 | 01:27 PM
JimBlake's Avatar
Default Re: rising of temp. close to over heating (cd five)
Did you flush with water or use something like Prestone SuperFlush?? Maybe scale buildup if you only rinsed with water?
Did you put in a new thermostat? They're cheap & maybe yours is sticking closed?
Old Nov 3, 2004 | 03:29 PM
DaChoZn1's Avatar
Make sure the radiator cooling fan is kicking on. If not, chk the fan switch and fan motor. If the fan is working properly then check your thermostat. Good luck.
Old Nov 3, 2004 | 04:19 PM
LiL accORd RideR's Avatar
hey, you should probably have the belt that powers the fan checked as well. This happened to me once, and the car overheated after a while. But other than that, just check out the thermostat. Hope this helps.
Old Nov 4, 2004 | 07:56 AM
LISTO~'s Avatar
Default Re: rising of temp. close to over heating (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Did you flush with water or use something like Prestone SuperFlush?? Maybe scale buildup if you only rinsed with water?
yeah i just flushed it with water. i didnt know there were flush products out there.
ill check the thermostat this weekend. thanks guys
hotcivicsi
11
Apr 9, 2009 06:19 PM
BlackEkB20
Jun 19, 2008 01:54 AM
lblingldawg
May 5, 2006 02:46 PM
tianporn
Jul 29, 2005 11:44 PM
chad
Sep 25, 2003 12:52 PM
