Battery dies fast
Old Nov 3, 2004 | 09:46 AM
spicoli's Avatar
Default Battery dies fast
My problem is when the car is off, and i have accesories running the battery tends to drain almost instantly. If i turn my stereo up the hu cuts out, only if the car is off, like it's not getting enough power, if the car is on no cut out. Also when i went to get in the car this morning battery was cooked, so i had to bump start it, If i let it run for a couple of minutes it starts just fine, like normal so i think the alt is oK
Help would be great!
Old Nov 3, 2004 | 09:48 AM
Turbo E's Avatar
if your batt is about 5 yrs old. replace it.
Old Nov 3, 2004 | 11:00 AM
bonta-kun's Avatar
Default Re: (Turbo E 604)
same thing happend to me but i replaced the battery and it was all good
at least ur car didnt die out on the top of a canyon road
we had to roll it down and kick start it
good time
Old Nov 3, 2004 | 11:13 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Battery dies fast (spicoli)
you mayhave cells dropping, and it is no longer holding a charge. i would replace it with a yellow top if you have lots of accessories.
Old Nov 3, 2004 | 11:52 AM
jethawk's Avatar
Default Re: Battery dies fast (boostedcivicsir)
if the alt is working then it sounds like its not holding the charge.... Time for a replacement!!!
Old Nov 4, 2004 | 06:59 AM
spicoli's Avatar
Yep replaced the battery last night, started better than it did since i owned the car, so i'm gonna have to say that's the cause. Thanks for the help yo guys
randomtask77
Oct 6, 2011 01:16 AM
tlsole
Jan 14, 2010 07:35 AM
rawsx
Mar 10, 2008 10:41 AM
W O T
May 8, 2007 11:38 PM
W O T
May 8, 2007 10:36 AM
