car will crank..progressively getting weaker though wont start.
Old Nov 3, 2004 | 09:02 AM
wompwomp61's Avatar
Default car will crank..progressively getting weaker though wont start.
alright..i've been having tps problems since i got my motor. havent gotten around to putting it in. no time. last night/today i've been trying to start my car. it cranks but thats it..this is normal it usually does this and i have to wait anywhere between 20 seconds an an hour for it to finally start. but there is no start. just crank, and every time i go to start it, it sounds weaker and weaker. i just went out there and it got so weak to the point where it hardly cranks at all. all the lights are insanely dim and its like it JUST has enough power to crank. I can only think of two things, alternator or battery. yes i know i should get around to doing the tps but between school and work i havent had the time to take off the throttle body and seeing as i've never done it before, i figure i'll need a little extra time.
Old Nov 3, 2004 | 09:35 AM
wompwomp61's Avatar
Default Re: car will crank..progressively getting weaker though wont start. (wompwomp61)
if i let it sit for a couple minutes it "recharges" then loses it while cranking
Old Nov 3, 2004 | 10:02 AM
Brownjd's Avatar
your battery is dead from cranking so much... simple as that
Old Nov 3, 2004 | 10:05 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: car will crank..progressively getting weaker though wont start. (Brownjd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd &raquo;</TD></TR><TR><TD CLASS="quote">your battery is dead from cranking so much... simple as that</TD></TR></TABLE>
also your original problem may lye in your distributor.
Old Nov 3, 2004 | 10:24 AM
wompwomp61's Avatar
Default Re: car will crank..progressively getting weaker though wont start. (LudeEFv2.0)
i've got a zc swap, so shouldnt the distributor be fairly new? bump for more answers, i have work in a half hour and i need my car
Old Nov 3, 2004 | 10:51 AM
LudeEFv2.4's Avatar
most dizzys that come with ZC swaps are used and have been sitting in a warehouse for who knows how long. Remove the cap and rotor assembly to see if there is any powder like substance or discoloring. Also check to make sure you have fuel pressure.
Old Nov 3, 2004 | 12:11 PM
wompwomp61's Avatar
i have no idea where the cap and rotor are nor how to check them..i searched and found kaputski, so if you or anyone can help me out. i've seen people say "check your cap and rotor" in so many posts but no one ever explains how to do it.
Old Nov 3, 2004 | 12:46 PM
wompwomp61's Avatar
bump for cap and rotor check info
Old Nov 3, 2004 | 01:09 PM
LudeEFv2.4's Avatar
cap is the plastic part of your dizzy where the plug wires are pluged in. once you remove that you will see the rotor.
Old Nov 3, 2004 | 01:42 PM
CRX_Control's Avatar
rotor is the thing that spins around when you open the dizzy
Old Nov 3, 2004 | 04:01 PM
wompwomp61's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.0 &raquo;</TD></TR><TR><TD CLASS="quote">cap is the plastic part of your dizzy where the plug wires are pluged in. once you remove that you will see the rotor.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">rotor is the thing that spins around when you open the dizzy</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.0 &raquo;</TD></TR><TR><TD CLASS="quote">most dizzys that come with ZC swaps are used and have been sitting in a warehouse for who knows how long. Remove the cap and rotor assembly to see if there is any powder like substance or discoloring. Also check to make sure you have fuel pressure.</TD></TR></TABLE>
alright...so i'll check it..so when i look at them..i'm looking for poweder like substances..or discoloration..what color shouldi be finding in there? and how will i know if there is something wrong in there. and how do i check the fuel pressure? i really need my car running so any help is much appreciated
Old Nov 3, 2004 | 07:17 PM
wompwomp61's Avatar
ttttt
Old Nov 3, 2004 | 08:06 PM
SIRef9[831]'s Avatar
i had that same problem when i intalled my swap. i thought it was the battery i bought a new one. i thought it was the alternator. it still kept on doing it. so i took it to a shop and this hole time it was the ignition switch. SO in my exprerience i think buy those two parts if its not both of them then u know its your ignition switch not the hole thing though just the wiring.
Old Nov 3, 2004 | 08:55 PM
wompwomp61's Avatar
alright...so i'll check it..so when i look at them..i'm looking for powder like substances..or discoloration..what color shouldi be finding in there? and how will i know if there is something wrong in there. and how do i check the fuel pressure?
Old Nov 3, 2004 | 08:59 PM
wompwomp61's Avatar
also your original problem may lye in your distributor.</TD></TR></TABLE>
well it used to throw a code 7. and most of the time (though as of late it doesnt do it nearly as much) it would rev up and down up and down up and down whenever it was in neutral.
Old Nov 4, 2004 | 09:18 AM
wompwomp61's Avatar
b
u
m
p
Old Nov 4, 2004 | 11:34 AM
LudeEFv2.4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wompwomp61 &raquo;</TD></TR><TR><TD CLASS="quote">
it would rev up and down up and down up and down whenever it was in neutral.</TD></TR></TABLE>
thats your IAC. located on the back of your intake manifold. your car will also do that if you are low on coolant.
Old Nov 4, 2004 | 02:17 PM
wompwomp61's Avatar
come to think of it i am indeed low on coolant..but it was throwing the code for it..though it doesnt do it anymore
osn grind
12
Aug 15, 2011 08:47 AM
mish__
Aug 7, 2011 10:29 PM
EjSex
Aug 17, 2007 08:20 PM
4runner
10
Jun 20, 2005 08:40 PM
dingusjt
Jan 5, 2005 09:59 AM
