doing a rear disc swap have a ?
Old Nov 3, 2004 | 08:56 AM
forlorn76's Avatar
Default doing a rear disc swap have a ?
my donor car has a few wires attached to the rear brakes that lead to the trunk..what are they for and do i need them ? they end in an orange connector..both cars are 4g's a 91 lx and 92 ex..thanks
Old Nov 3, 2004 | 09:01 AM
momstaxi's Avatar
Default Re: doing a rear disc swap have a ? (forlorn76)
those wires are for the anti-lock brakes system. simply cut the wires on them when transferring the rear suspension as you will not be able to use it.
Old Nov 3, 2004 | 09:03 AM
.bagged's Avatar
Default Re: doing a rear disc swap have a ? (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">those wires are for the anti-lock brakes system. simply cut the wires on them when transferring the rear suspension as you will not be able to use it.</TD></TR></TABLE>
Yep. They are abs sensors.
Unless you feel like putting abs into your vehicle. In which if you do, i have a full setup for you that you can just have.
Old Nov 3, 2004 | 09:26 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">... simply cut the wires on them when transferring the rear suspension as you will not be able to use it.</TD></TR></TABLE>Or remove the sensors & sell them. They're kinda pricey to buy new ones...
Old Nov 3, 2004 | 10:30 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: doing a rear disc swap have a ? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Or remove the sensors & sell them. They're kinda pricey to buy new ones...
Yeah, I would just unbolt them from the knuckles and then from the car. You can pull the whole rear ABS sensors/wiring from the rear without cutting. Thats the way I did it when I sold my rear disc assembly from my totalled Accord.
sTEGasaurus
Jan 28, 2010 08:41 PM
grandtheftlunchbox
Aug 17, 2008 01:29 AM
gsrpedro
Jan 6, 2007 12:47 AM
HBADGE
Jun 4, 2005 04:36 PM
Dveloped
10
Nov 12, 2003 02:13 PM
