vent blower isn't working on number 1,2
My 92 vx only 3,4 works for the vent. Would anyone know what to check for? 1,2 doesn't blow but when i put it on 3,4 it'll blow as normal. thanks.
If it's anything like the 91's, there is a resistor pack that bolts into the blower assembly, usually on the front edge, pointing up. That's what controls the speeds. They are about 20-25 from Honda, at least for the older ones.
edit - just checked the service manual, and it is indeed where I thought.
if the blower is working on 3 and 4 then it is the blower motor resister as rpr has said. this is fairly common. also it is exactly were rpr days and all you will need is a phillips screwdriver to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonTypeR10 »</TD></TR><TR><TD CLASS="quote">i have the same problem do u just replace the resister pack and it will be just fine??</TD></TR></TABLE>
The failure could be either the switch or the resisitor on the blower. Either should be easy to test.
riceboyEFsi
Dec 24, 2003 11:23 AM
EGhatched
Nov 19, 2003 09:29 PM
