my 1989 CRX and i have no clue whats wrong
Old Nov 3, 2004 | 07:58 AM
Schaz's Avatar
Default my 1989 CRX and i have no clue whats wrong
okay ive had the car for about 5 months and always had this problem....i boggs out....it like hopps when i shift in 1st.....then usually in any other car you can go into 4-5 while goin like 30-40....i cant my car dies...its like choking itself......there is a loud *** knocking from my motor...and also i smell oil...im thinkin its my valve cover gasket cuz i took it off and never used liquid gasket...but still my car is bogging...then when u listen to the exhaust it sounds like its missing a beat when u drive....if you can understand that....any suggestions? i really want to fix this cuz its pissin me off thanks!!
Old Nov 3, 2004 | 08:25 AM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: my 1989 CRX and i have no clue whats wrong (Schaz)
well, not all four cylinders are firing. start by checking with spark, then fuel and so on.
Old Nov 3, 2004 | 11:31 AM
Schaz's Avatar
Default Re: my 1989 CRX and i have no clue whats wrong (LudeEFv2.0)
i have spark...and i have fuel.....hm....any other comments? oh yea i did a compression test...and in cylinder 2 i have 30 lbs...would that be cause by bad valve seals? please feel free to comment
Old Nov 3, 2004 | 01:04 PM
OptimusPrimeX's Avatar
in the #2 cylinder, take out the plug wire while its running, and see how much it hestitates. Is it possible that you somehow managed to get the piston to knock the Valve?... it might be the the valve + seal. Its most likely not your Valve cover gasket, that wouldn't cause your problems. MOst of the time the valve cover gasket seals correctly if the surface is clean w/out extra sealant, unless the gasket has ridges from wear.
Old Nov 3, 2004 | 01:26 PM
deftones0817's Avatar
Default Re: my 1989 CRX and i have no clue whats wrong (OptimusPrimeX)
maybe you have the spark plugs wires in the wrong order? Just an guess.
DEF
Old Nov 3, 2004 | 01:54 PM
egchan's Avatar
how does your headgasket look? you need to tear it down, at least pull the head. whatever's wrong with it won't be fixed externally.
Old Nov 6, 2004 | 03:07 PM
Schaz's Avatar
Default Re: my 1989 CRX and i have no clue whats wrong (Nodo)
yes it offically sucks...i have 0lbs of compression in cylinder 2
Old Nov 6, 2004 | 03:58 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
drain the oil and cut the filter open with a sharp chisel. check for chunks of metal. you have either broken rings, bad headgasket or bent/burnt valve.
whats the compression in the other cylinders? if its smoking white or the radiator hoses feel like they have tons of pressure and the engine runs better with the radiator cap off, its a leaking headgasket.
Old Nov 7, 2004 | 09:06 PM
Schaz's Avatar
Default Re: my 1989 CRX and i have no clue whats wrong (mike_belben@yahoo.com)
i have 180 in the rest of my cylinders... this is pissin me off
Mnguyen559
Apr 9, 2013 01:25 PM
netfreak
23
Jun 20, 2011 10:34 AM
dhatcher2002
Nov 25, 2008 10:26 AM
93sivtec
May 27, 2007 03:05 PM
Duckz
Jul 22, 2002 09:54 PM
