Greddy Profec B SPEC S (NEW ON MARKET)
I just recieved a shipment of the NEW Greddy Profec B Spec S Boost controllers. Please let me know if your interested in purchasing one. Email me, PM me, IM me, or Call anytime for a price quote. They are IN STOCK READY TO SHIP. Thanks.
Based off the original Greddy Profec B, the Spec S is one of the simplest, easy to use electronic boost controllers on the market today. Same features as the Spec 2 but with the simplicity of the old Profec B that you love. Has the proven reliable twin-solenoid valve control motor. There are two presets labeled Lo. and Hi, as well as a Balance **** to alter the wastegate boost response. This unit also can be used with both integral/actuator or external/poppet style wastegates Good for twin and sequential turbo setups. Compatible with our Remote Switching System.
NEW Simple Electronic Boost Controller:
Simple, Reliable, Hi Performance Boost Control (easy to set as a manual boost control w/ electronic response)
Based on the ever popular original B-spec (but comes w/ higher capacity solenoid valve)
2 manual "Set Boost - Lo & Hi" Presets (Increase boost with a turn of a ****)
"Gain" Boost Adjustment (wastegate compensation, to keep constant boost)
Program up to 3.0 kg/cm (42.66 psi) Max
Hi-Volume Solenoid Vavle & Pressure Sensor (extra-fast wastegate response and consistency)
