anyone knows where i can get a tread for control arm installation??
Old Nov 3, 2004 | 07:10 AM
j_kevin_ca's Avatar
Default anyone knows where i can get a thread for control arm installation??
contents as title says. and thanks alot!
Old Nov 3, 2004 | 07:23 AM
EE_Chris's Avatar
Default Re: anyone knows where i can get a thread for control arm installation?? (j_kevin_ca)
Front LCA
You need to remove #9, 12, 13 + disconnect the lower ball joint from the LCA.
Rear LCA
Part #4 is the LCA - you need to remove the two #19 bolts as well as the thru-bolt securing the shock to the arm (this bolt goes through item #13).
corkss
10
Mar 19, 2009 07:00 PM
mymomsdrunk
Mar 5, 2008 08:38 AM
ActiveAero
May 14, 2006 10:22 AM
eg2_RE
Apr 1, 2004 05:56 PM
vteg
Jul 14, 2002 03:19 AM
