Add power steering to a 5th gen civic hatchback cx or vx.92-94
civic hatch.I want to but a 3rd gen B18C1 which comes with power steering pump but what else would i need to hook up the power steering on a 92-94 civic cx or vx? I need the rack and pinion and what else? Thanx guys
buying the whole subframe in one piece from a salvage yard is the best bet. you'll need the fluid reservior.
you can use any eg or 94-00 integ subframe. only thing is not every applicatioon has the same power steering pump. that means you may have to buy the correct power steering line to bolt up to the pump.
i used to run an itr steering rack on my old 92 eg. used the itr power steering pump too.
Lookincrazy
Dec 27, 2001 05:47 PM
