What i see in my ecu help homie!
IF my broken into ignition is on my Ecu light is solid red no blinks just on.MY car will start at what must be .5 rpms but not a damn thing from my pedal. i pump it it dies.Is the ecu broke?Ive been having lots of ignition/start problems since i jimmy rigged or busted past the tumbler it used to beep when i turn it on two or three fuses later no beep?answer all these for me and save a young thugs crux. thanx tmak 360 wa.
Dood, you are way to hood. We elite bastards here at Honda tech don't take kindly to "busting past the tumbler." The only way to get a solid response is to use proper grammar and ask sensible questions.
And for the record, your ECU is frozen. You've thrown to many codes at once. Good job.
put another steering column in that beotch and get her done!! Also you will have to get a key made so ask junkyard for proof that you bought steering column and get vin. I had to do this it sucks *****. Next start her up and see what over codes you are throwing. Or just pulled hazard fuse and give it a few minutes. Then see if ecu is still throwing a solid code.
DEF
DEF
dc5campo
Engine Management and Tuning
Nov 7, 2010 05:15 PM
