CODE 15
Old Nov 2, 2004 | 07:59 PM
dviperbigt's Avatar
Default CODE 15
I am a mechanic at an independent garage. I was doing a tune up on a 1990 accord. I replaced plug wires, cap, rotor. All bought at NAPA. I also replaced plugs with ngk platium.The car started up fine then it shut off and I got a code 15 so I replaced the distributor also bought at NAPA. Now the car will start some time and run for a little while then die. But other times it wont start at all. I have checked the black&yellow wire from the ignition and it is fine. I also have researched this alot but no one has been able the give me a good answer on how to fix it. Has anyone fixed this before or know how to fix this problem. I would really appreciate the help. It would help alot if it was possibe to call me. (864) 207-0234.
Thanks,
TJ
Old Nov 2, 2004 | 08:31 PM
PrettyLude's Avatar
check the main relay
Old Nov 3, 2004 | 03:33 AM
dviperbigt's Avatar
Default Re: (PrettyLude)
Where is the main relay located?
Old Nov 3, 2004 | 08:36 AM
dviperbigt's Avatar
Default Re: CODE 15 (dviperbigt)
I changed main relay and tested harness and it did not fix the car. Car will sometimes crank up and run, but once the car warms up, it shuts off and shows code 15.
Thanks,
TJ
Old Nov 3, 2004 | 05:14 PM
JimBlake's Avatar
check your other thread...
Old Nov 4, 2004 | 03:39 AM
dviperbigt's Avatar
Default Re: CODE 15 (JimBlake)
Already Checked them.
Thanks,
TJ
Old Nov 6, 2004 | 10:06 PM
only1crx's Avatar
See im going threw the same thing right now on my 88 dx hb, i think it has to do with a wire that is touching another, causing code 15 check the ground wire from the starter i have a feeling thats it.
Old Nov 7, 2004 | 09:21 AM
greyrex's Avatar
Is the check light on permanently and did you tried resetting your ecu by taking off the hazard fuse?CHeers!
ketchup214
Apr 17, 2010 03:03 PM
slammedvtec
Apr 17, 2008 02:17 PM
messeduprex
Oct 18, 2005 06:43 PM
dviperbigt
Nov 5, 2004 08:01 PM
psicrxsi
11
Oct 1, 2003 09:15 AM
