Catch can - is this how the inside looks?
I received my Moroso/Endyn Oil Breather/PCV/Catch-Can
yesterday, and was having a discussion with soneone on how it works (looks inside).
They claimed that all it is, is a empty "tank" and there are no baffles...he said in his he can look through the bottom (drain) and while there is a "plate"(baffle) he can see out the top...which would inply that there is only one baffle.
On mine...if I look through the top...I see one plate (baffle) and through the slits I can see a second baffle below the first which has its own slits (real hard to see but you can see it). Im not sure how many levels of baffle there are...but I think we have different catch-can models. His is a Moroso as well though.
yesterday, and was having a discussion with soneone on how it works (looks inside).They claimed that all it is, is a empty "tank" and there are no baffles...he said in his he can look through the bottom (drain) and while there is a "plate"(baffle) he can see out the top...which would inply that there is only one baffle.
the bottom hole on the side is for draining too. Connect that and the bottom hole with a T joint and drain the oil back to the driver side plug on the block.
[Modified by citanest, 11:47 AM 12/22/2001]
purduinasi
Sep 22, 2006 04:37 PM
