92 EX not starting!! All of the sudden!
Old Nov 2, 2004 | 05:32 PM
D A 9's Avatar
Default 92 EX not starting!! All of the sudden!
HElp! my dad's accord all of the sudden decided it wouldn't start anymore!
He came back from a NC trip yesterday and the car was perfect, as it always is.
all of the sudden this morning the car woudn't start anymore, the engine turns but doesn't start. as soon as you try to start it you can smell a lot of gas coming from the engine bay. Any body got any ideas? where could I start?
Thanks for any help!!
Old Nov 2, 2004 | 05:41 PM
portenio78's Avatar
Default Re: 92 EX not starting!! All of the sudden! (D A 9)
Sounds like igniter module inside dizzy...start there???
Old Nov 2, 2004 | 06:54 PM
Teglessb18's Avatar
Ya same thing happened to me on my 92 accord and it is some relay computer chip. Because my engine would turn over and everything as well. Good luck.
Old Nov 2, 2004 | 07:53 PM
scrubachu's Avatar
Default Re: (Teglessb18)
most probable cluprit is the main relay. its known to be faulty in 4th gens. try that first. under the dash of the driver side.
Old Nov 3, 2004 | 04:33 AM
Filthy Focker!'s Avatar
Default Re: (scrubachu)
Enough with all these "most probably ****"
Do you have spark?
How fast it is cranking?
fs
Old Nov 3, 2004 | 05:19 PM
D A 9's Avatar
Default Re: (filthy_shovel)
Thanks for all the help!
After looking at it a little better today ... there is no spark, it cranks just as normal(like it does just before the engine starts) except it doesn't start...
I thought it might have been the Fuel relay, but please correct me if I'm wrong: IF the relay is bad it wouldn't allow the car to pump any gas, right? cause I do smell unburnt gas every time I try to start it.
at least now I know it's a sparking problem, if the distributor was going bad it would trigger the CEL, right? or not always?
Old Nov 3, 2004 | 05:52 PM
hawkmgc's Avatar
Default Re: (D A 9)
Most of the time the no spark in an F22 motor is from the internal coil in the distrib.
If you have an external distrib. (very rare or only if engine has been changed) Again most likely the coil.
PM me and I can set u up with a replacement or with a person that carries the same new replacement coil.
bwk
Dec 29, 2017 04:49 PM
Mhilton
Mar 16, 2016 08:40 AM
Crxlsturbo
Jul 7, 2010 01:39 PM
paceman
Jan 14, 2008 11:57 AM
civic7gen
Jul 20, 2002 03:45 AM
