valve adjustment specs for b16 with ctr cams
Old Nov 2, 2004 | 03:54 PM
B16Civic93's Avatar
Default valve adjustment specs for b16 with ctr cams
what in inches. do you adjust the valves to with a b16 with ctr cams?
Old Nov 3, 2004 | 02:58 PM
Seth21's Avatar
Default Re: valve adjustment specs for b16 with ctr cams (B16Civic93)
.006 on the intake .008 on the exhausts with the engine absoutley COLD!
Old Nov 3, 2004 | 03:08 PM
drdisco69's Avatar
Default Re: valve adjustment specs for b16 with ctr cams (550whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 550whp &raquo;</TD></TR><TR><TD CLASS="quote">with the engine absoutley COLD!</TD></TR></TABLE>
Dis be true. Head must be under 100 degrees, and room temp is preferable.
Old Nov 3, 2004 | 03:28 PM
hondaguyef's Avatar
Default Re: valve adjustment specs for b16 with ctr cams (drdisco69)
I have always had the best accuracy when the car has not been started that particular day. If you have Saturday off, Just adjust them 1st thing in the morning.
Phil
Old Nov 3, 2004 | 03:39 PM
drdisco69's Avatar
Default Re: valve adjustment specs for b16 with ctr cams (hondaguyef)
Thats true. It can be done accurately with the head below 100 degrees, but for troublesome motors, Honda recommends you park it inside and do it the next day. I came across the Honda bulletin on this yesterday, as luck would have it.
EJ1_manG
Sep 19, 2007 08:38 AM
Earthworm Jim
10
Nov 10, 2005 12:35 AM
Suck my DX
May 26, 2005 09:25 PM
SPOON_FED_DC_2
Apr 4, 2005 09:33 PM
JohnnieChimpo
Mar 14, 2005 10:29 PM
