accord pwr door locks
Old Nov 2, 2004 | 03:14 PM
nickromeo's Avatar
Default accord pwr door locks
hey whats up guys, my friend jjust picked up a 95 accord EXR coupe (stock) in really good condition (but high k's) the car is mint but he's experiencing a problem with his door locks this is how he explained it to me :
I got this problem when I goto lock my door, it is in the "LOCK" position, however it continues to try and lock the door. You can hear the mechanism go on. It tries as many times as it wants too....... sometimes into the TEENs before it stops. Sometimes just once will do it.
i have very little idea to how to solve stupid electical problems like this hav any of you experienced this kind of ****?
id like to take it apart and figure out if its a mechanical problemo or an electrical one.... thanks!
Old Nov 3, 2004 | 05:39 PM
optikal_fade's Avatar
Default Re: accord pwr door locks (nickromeo)
try lifting up the door handles when you lock the door...if you dont...it will make that awful noise that sounds like they are grinding. or you can get an alarm with keyless entry...thats what i have on my accord...and it does do that at all.
Old Nov 3, 2004 | 06:40 PM
Sex Cells's Avatar
Default Re: accord pwr door locks (optikal_fade)
mine does that too, help would be appreciated very much!
Old Nov 3, 2004 | 07:13 PM
numbinside's Avatar
Default Re: accord pwr door locks (Se7ens Travels)
im having that problem also everyonce in awhile and its with keyless entry..
Old Nov 4, 2004 | 05:52 AM
namBANG's Avatar
Thanks nick for posting the msg for me.
Alright... it seems as tho i wasnt clear enuff.
I will now type out the entire process... to which nick thinks its an electrical problem. I am not a "car-guy", so i'll explain in clear detail. Please dun think im condescending.
Example 1.
I am using keyless entry to lock my door (im on the outside). But once i do... it continues to lock like crazy sometimes - as i have mentioned it can try locking itself upto 10+ times. When i peak inside, i see the lock in the "LOCK" position - and it is still trying to lock itself.
Example 2.
I am inside the car. I go and flip the flap to the lock position (95 coupe... its a flap right by the handle), and it occurs again. (upto 10+ times).
In both cases you can hear the mechanism trying to lock itself... however its already inthe lock position
I hope this is clear enuff for you guys :S
Also... to Optikal Fade: Dood. the lock wont lock if u dont lift the handle ..... mine does lock. so im not sure where u were going with ur post
Numbinside: yo bro... sit inside the car and lock it? and PLEA SEtell me if u get the problem too.
Old Nov 4, 2004 | 06:03 AM
tomtom211's Avatar
yeah, mine does that too, seems to be common among 5th gen accords.
Old Nov 4, 2004 | 06:52 AM
namBANG's Avatar
Default Re: (tomtom211)
tom, did u get it fixed?
if so... how?!
a DIY job... or did u get it done @ the shop.... or the dealer?
Old Nov 4, 2004 | 01:08 PM
mrvinyl33's Avatar
New User
Yeah, I've heard of that happening in 5th gen Accords too. I thought I read it was related to the lock actuator.
Old Nov 4, 2004 | 01:24 PM
AccidentproWn's Avatar
my 97 does that too someone has to know how to fix this
Old Nov 4, 2004 | 01:36 PM
namBANG's Avatar
Source #1:
Most likely, it's the locking mechanism/switch... there should be a sensor inside which tells the locking brain that it's locked, when it doesn't the locking brain tries to repeatly lock the switch, and doesn't know when it's actually locked
Anyhoo. TOM and ACCIDENT.... do u guys both oil spray your car? my dad said that he knows a mechanic and HE said that it was liekly due to the oil spray.... LMK if u do!!!!
Old Nov 4, 2004 | 02:31 PM
Sex Cells's Avatar
Default Re: (namBANG)
my accord will never actually lock itself, it will do that thing where it trys to lock (only it never quits tell i make it) the lock flap itself keeps going and going, its like somethings stopping it, id check it but my cars still in the shop getting the front end replaced thanks to the kind bitch that decided my car would look better without a fender andbumper
DFH
Nov 23, 2014 05:32 PM
mvargas08
May 22, 2010 09:25 PM
honda_accord_215
Nov 18, 2005 10:15 PM
