Add power steering to a 5th gen civic hatchback cx or vx.92-94
Old Dec 21, 2001 | 11:41 PM
Lookincrazy's Avatar
Default Add power steering to a 5th gen civic hatchback cx or vx.92-94
Add power steering to a 5th gen civic hatchback cx or vx.92-94 civic hatch.I want to but a 3rd gen B18C1 which comes with power steering pump but what else would i need to hook up the power steering on a 92-94 civic cx or vx? I need the rack and pinion and what else? Thanx guys
Old Dec 22, 2001 | 04:20 PM
clutch359's Avatar
From: somewhere between the motor and tranny, putting power to the wheels...
Default Re: Add power steering to a 5th gen civic hatchback cx or vx.92-94 (Lookincrazy)
why go thru all the trouble to add power steering, it really doesnt take that much more effort w/out power steering. plus, at higher speeeds you wont even notice you dont have it.
Old Dec 26, 2001 | 08:33 AM
F22B-EF's Avatar
much better without power steering....
Old Dec 26, 2001 | 10:03 AM
JD_B18CDX's Avatar
If you have a 17inch rim and wide tires, no pwersteering is a pain specially parking in tight spaces.
You will need.
1. Pump
2. Hoses
3. Rack and pinion with powersteering.
Old Dec 26, 2001 | 11:26 AM
90accord1's Avatar
Default Re: Add power steering to a 5th gen civic hatchback cx or vx.92-94 (johnd)
if you cant drive a civic that has a 19:1 non power steering rack with 17's then you either need to lift weights or get rid of the car becuase it should not even affect it that much.
Old Dec 26, 2001 | 11:31 AM
jgale's Avatar
This was covered not even 2 weeks ago! SEARCH my friend.
You need:
ps rack
ps pump
lines (for the above)
bracket that mounts to the head(for pump)
belt
reservior
be sure your crank pulley has the ring for the belt!
Old Dec 26, 2001 | 06:04 PM
jdmciviceg's Avatar
New User
Default Re: Add power steering to a 5th gen civic hatchback cx or vx.92-94 (jgale)
You need:
ps rack
ps pump
belt
reservior
I was about to say the same thing. I've seen this topic atleast 3 times. Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search Search
Old Dec 27, 2001 | 05:22 PM
SpoolinEK's Avatar
i believe you have to get the holes that connect from the power steering pump to the rack and pinion..from an integra..
Old Dec 27, 2001 | 05:47 PM
EG-cellent's Avatar
Default Re: Add power steering to a 5th gen civic hatchback cx or vx.92-94 (EG Civic)
you will also need the cross member for the power steering rack. the bolt holes do not lin up. DON'T ADD POWER STEERING!!!
GODSPEED33
Jan 5, 2007 11:26 AM
wilkerson05
Apr 18, 2006 08:33 AM
Lookincrazy
Dec 22, 2001 09:14 PM
