need help with air/fuel water temp gauge install
ok i hate to admit it but i need help (pics would help alot) i have a air/fuel (i know it's a light show) and a water temp i think its mech. (has a lil metal probe) both auto meter. if anyone could show me some pics that would be great i need to know how to do the mounting on the a-pillar and on the water temp gauge i still want to have the stock gauge hooked up also so if someone could show me how to do this it would be very helpfull and by the way i did search... and i couldnt find what i needed. i've had these gauges sitting in a box for a while (too long) i want to get them out of my house and into my car. of yeah the car is an ef hatch and i have a dual gauge pod t.i.a.
get a pod to mount them to the pillar
for the a/f you have to hook up the power/ground/and then run sensor wire to your ecu wire or to your O2 sensor
for the water temp, you will have to tap into a water hose somewhere and put in a bung to screw in the sensor.
hope it helps.
hope it helps.
do you have any pics? i do have a pod i need to know how to "hook" it up to the pillar on the car and as for the water temp i need to know how to "tap" into a water hose and which one?
temp gauge is an easy install. best place i have used and will use again is where the stock bleeder screw for the coolant is...should be where the top radiator hose connects into the head....
-drain coolant
-disconnect top radiator hose
-i think they are just held on there with hondabond or something (don't exactly remember)
-unscrew the bleeder all the way and remove
-drill/re-tap hole for the temp sender
-install everything back
-drain coolant
Put the temp gauge sender into the stock location.... the one in your dash will no longer work but thats why you bought an aftermarket one for right...
