do 2000 SIR back arms and brake assembly ..fit 94 hatch back eg..
Old Nov 2, 2004 | 07:42 AM
fastest's Avatar
Default do 2000 SIR back arms and brake assembly ..fit 94 hatch back eg?????/..
please let me know before i buy of a friend tahnks guys
Old Nov 2, 2004 | 08:53 AM
fastest's Avatar
Default Re: do 2000 SIR back arms and brake assembly ..fit 94 hatch back eg?????/.. (fastest)
no one knows?
Old Nov 2, 2004 | 09:00 AM
chad's Avatar
Moderator
need to know what you are talking about....
Old Nov 2, 2004 | 09:17 AM
GTI_guy's Avatar
Default Re: do 2000 SIR back arms and brake assembly ..fit 94 hatch back eg?????/.. (chad)
First of all as a Canadian I would like to clarify to anybody who doesn't know that Canadian SiR = American Si. In Canada we have both an Si and an SiR but our SiR is equivilent to the American Si. If you already knew that than I'm sorry for chiming in here.
Old Nov 2, 2004 | 09:49 AM
chad's Avatar
Moderator
Default Re: do 2000 SIR back arms and brake assembly ..fit 94 hatch back eg?????/.. (GTI_guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTI_guy &raquo;</TD></TR><TR><TD CLASS="quote">First of all as a Canadian I would like to clarify to anybody who doesn't know that Canadian SiR = American Si. In Canada we have both an Si and an SiR but our SiR is equivilent to the American Si. If you already knew that than I'm sorry for chiming in here. </TD></TR></TABLE>
yes i know that...but what is he talking about?!??!
rear brakes arms what?
Old Nov 2, 2004 | 10:05 AM
94eg!'s Avatar
#1 Super Guy
Loved
I think everything but the e-brake cables, and lower arms will work on your 94. You can use your stock civic lower arms (or integra ones if you want sway-bar mounting holes), and you'll need civic si e-brake cables (integra cables will work, but the drivers side one is a little funky). I know the proportioning valve wont work...
Old Nov 2, 2004 | 10:35 AM
fastest's Avatar
Default Re: do 2000 SIR back arms and brake assembly ..fit 94 hatch back eg?????/.. (94eg!)
thanks guys and gti_guy for the candian to american translation b/c i ddint even no that hahahahah ...but yea thanks for answering ill buy them then ....ill just use my lower control arm ...but verything else bolts on like main arm and brake assembly and i jsut need to get si brake cables........
Old Nov 2, 2004 | 11:28 AM
fastest's Avatar
confirm?
Old Nov 2, 2004 | 03:29 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I think everything but the e-brake cables, and lower arms will work on your 94. You can use your stock civic lower arms (or integra ones if you want sway-bar mounting holes), and you'll need civic si e-brake cables (integra cables will work, but the drivers side one is a little funky). I know the proportioning valve wont work...</TD></TR></TABLE>
ONCE AGAIN WRONG INFORMATION!!!!!!!
rear LCA's from a 96 up civic WILL NOT WORK on a 88-95 civic!!!!!!!!!!!!!!!!!!!!!!!!!!! period....you need them from a 94 up integra if you want to run a sway
the Ebrake cables from any rear disk civic will work....or 90 up integra!!!! i know cause i've done both!!!!
please knwo what you are talking about before you post!!!
Drumatik
Mar 26, 2008 06:08 AM
.:BAS1K:.EF
29
May 23, 2007 12:37 AM
93SIRII
Nov 20, 2003 06:10 AM
Ep3soulpower
17
Jun 5, 2003 10:49 PM
ChiNoS
Mar 21, 2003 06:05 PM
