OBD 1 zc is 89 hatch??
I was wondering if anyone could tell me the mount that i will need for a OBD 1 dohc zc swap into an 89 hatch, the motor is in but the mount just doesnt line up. i am also not getting any fuel pressure at all. Before i check the fuel pump i want to make sure it has nothing to do with my computer or any sensors?? thank you
I am using the stock tranny. the mount that doesnt line up is the only mount that is on the actual motor. I am putting OBD 1 zc into an 89 honda civic si. I have it so it starts just gets no fuel pressure. thanx again.
You have to take the motor mount off of a 4g engine (d15 -d16) (the one that was in the car before the switch) and replace it on the ZC. Means taking off the timing cover, etc. to get in there. Place a jack under the left side of the engine to support it, take off the valve cover, and the top timing belt cover and I think you can then remove the motor mount. Usually it is done before the swap is placed in the car.
Jay
Jay
91'ZC boosted
Jun 18, 2009 11:02 AM
