fuel pump fuse went, oil all over valve cover, what should i do?!
Old Nov 2, 2004 | 05:07 AM
gtowni3's Avatar
Default fuel pump fuse went, oil all over valve cover, what should i do?!
i replaced the fuse and it works now, but do i have any bad seals or gaskets that caused the leak?
Old Nov 2, 2004 | 05:09 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: fuel pump fuse went, oil all over valve cover, what should i do?! (gtowni3)
Did you figure out why the fuse blew in the first place?
Old Nov 2, 2004 | 05:10 AM
SSBPGSR's Avatar
its probobly that there is a screw or two missing on the underside of the spark plug cover mang. remember u only had 2 or 3? so its proboboyl not pushing the gaskets around the spark plugs down and its seeping up through there, there was no oil on the plugs so its not comming though there cylinders. its just those gaskets arent pushed down hard enough. get some screws and tighten it down and it will go away.
Old Nov 2, 2004 | 05:51 AM
gtowni3's Avatar
Default Re: fuel pump fuse went, oil all over valve cover, what should i do?! (SSBPGSR)
WOW WHY ARE YOU AWAKE SO EARLY ADAM!, AND YES U KNOW THE PROBLEM CUZ UR THE ONE WHO PUT THE COVER BACK ON lol, thanks mang
collkid
May 12, 2017 11:39 AM
rice a roni
Mar 12, 2007 05:23 AM
oneslowstd
Nov 22, 2006 03:01 PM
square_1
Jul 21, 2006 11:14 PM
si foo
Apr 27, 2002 06:32 PM
