2000 si cluster...help?
Old Nov 2, 2004 | 12:46 AM
klomast3r's Avatar
Default 2000 si cluster...help?
I owned a 2000 civic si. I recently noticed where the RPM is at, there's a what appears to be some kind of indicator . I never seen it lite up. Could anyone tell what the heck this is? see pic.
Old Nov 2, 2004 | 12:52 AM
j nepo's Avatar
Default Re: 2000 si cluster...help? (klomast3r)
pic no worky
Old Nov 2, 2004 | 12:55 AM
K I T T's Avatar
no pic!
but judging to your explanation could be the Cruise control light.
Get that pic hosted somewhere else so it shows.
Old Nov 2, 2004 | 03:57 AM
spoonek9's Avatar
Default Re: 2000 si cluster...help? (K I T T)
Yellow ABS (Antilock Braking System) light. It will always be on unless you have ABS. Just remove the bulb from the back of the cluster.
Old Nov 2, 2004 | 04:04 AM
Buzzbomb's Avatar
Default Re: 2000 si cluster...help? (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">Yellow ABS (Antilock Braking System) light. It will always be on unless you have ABS. Just remove the bulb from the back of the cluster.</TD></TR></TABLE>
That's on the gas/temp side. Plus even that only applies to Canadian SIR's.
It's your cruise control indicator that's on the Tach side. The buld may be burned out. Either that, or you've never used your cruise.
Old Nov 2, 2004 | 04:08 AM
kKdARIAN's Avatar
Vice President/CEO
fix your picture... but from what it sounds like.. you got your answer'
Old Nov 2, 2004 | 04:47 AM
pdiggitydogg's Avatar
Not here, if thats what happens
If its on the tach's side its SRS light
If its next to the tach, on the bottom, its cruise control light
Old Nov 2, 2004 | 04:55 AM
nighttrain33's Avatar
Default Re: 2000 si cluster...help? (pdiggitydogg)
More than likely it would be this ^^^^. The SRS light is probably one of the most notorious (that and the cel).
-Shane
Old Nov 2, 2004 | 06:21 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klomast3r &raquo;</TD></TR><TR><TD CLASS="quote">I owned a 2000 civic si. I recently noticed where the RPM is at, there's a what appears to be some kind of indicator . I never seen it lite up. Could anyone tell what the heck this is?</TD></TR></TABLE>
Pic isn't working, but the indicator light in between your tach and the "Maintenance Required" reset button is the cruise control light. It illuminates green and says "CRUISE CONTROL." It will only light up when you have a speed set with the cruise control.
The light directly below your tach needle pivot is the SRS light. It should light up (red) briefly every time you start your car.
EM199dcs
Jan 25, 2007 10:58 AM
Jamied
Jan 22, 2007 11:23 AM
JimmyAtlantis
Dec 8, 2005 08:51 AM
spoonracer84eg
29
Nov 21, 2005 03:22 PM
Beezle
May 24, 2005 10:01 PM
