Drop forks???
Old Dec 21, 2001 | 07:40 PM
91ReXSI's Avatar
New User
Default Drop forks???
dont they make the car lower or something???
Old Dec 21, 2001 | 09:02 PM
bryant's Avatar
Default Re: Drop forks??? (91ReXSI)
Yes, good luck finding them.
Old Dec 22, 2001 | 01:45 AM
kefka's Avatar
Default Re: Drop forks??? (CR-X)
yea they had some a while back. DOHCDX has the only pair i have acually seen, there hella sweet. they were taken off the market for redesign, but i guess they forgot about them..
Old Dec 22, 2001 | 07:12 AM
91ReXSI's Avatar
New User
Default Re: Drop forks??? (madeinjapan)
why did they take them off??
Old Dec 22, 2001 | 08:38 AM
kefka's Avatar
wanted to make them stronger or something like that...
Old Dec 22, 2001 | 10:34 PM
kefka's Avatar
Default Re: Drop forks??? (DOHC DX)
dropforks DO rule!
Old Dec 23, 2001 | 12:02 AM
crxgurlllll's Avatar
Ive personally never seen them or even knew of their exsistence until now...
i have heard of drop spindles...they run about 3-400 bucks, require 15" wheels, available in red or blue.....Available from Ryane Motorsports....
Drop forks would be cool i guess...who makes them?
Old Dec 23, 2001 | 12:49 AM
brinks's Avatar
Chech the http://www.g2ic.com board. A member modified his strut to sit lower in the front fork giving him about another inch of suspension travel. This could possibly be done on an ef also.
here is the link to the thread. Again, its been awhile since i wrenched on an EF, but I think it would work. http://www.g2ic.com/forums/showthrea...&threadid=5829
[Modified by brinks, 4:58 AM 12/23/2001]
Old Dec 23, 2001 | 08:47 AM
kefka's Avatar
Default Re: Drop forks??? (brinks)
yea they come as a set with drop forks and pro arms, the arms are camber adjustable and are shortend so you get about an inch and a quarter or a drop there wery nice!
Old Dec 23, 2001 | 12:13 PM
BoostedED9's Avatar
has anyone tried the Ryane Motorsports knuckles and trailing arms????
Old Dec 23, 2001 | 12:56 PM
Default Re: Drop forks??? (ED9Hybrid)
id get them if they fit 14"s....sounds like a very nice product...a lil pricey tho...
Old Dec 24, 2001 | 12:01 AM
They dont look cheap to me! nobody I know has used them, but come on they cant be "cheap" A part like this has to be made pretty well doesnt it? I mean if this product were to fail, this company wouldnt be in business right?
As far as red or blue...thats just the color they chose to powdercoat them in...
Dont tell me a product is crap based on color and looks...I mean say i didnt like silver and orange...that would mean Hasport is Crap...right?
This is a special front spindle designed to lower the front of the vehicle by 1 1/2" without changing any of the control arm angles relative to the vehicle chassis. This is the industry-approved method of suspension lowering as it does not alter the manufacturer's geometry design.
In automotive circles the word spindle is used to describe an assembly which consists of a spindle, an upright member (which separates the upper and lower ball joints), a steering arm and a variety of brackets for mounting brake components etc. The actual spindle is the shaft about which the wheel rotates. On a "lowering spindle assembly", the shaft is raised in relation to the upright member, thereby having the effect of lowering the vehicle relative to the wheel.IMPORTANT WHEEL FITMENT NOTICE
A minimum of 15" wheels are required. Maximum wheel back side spacing is 143mm (5 5/8"). The back side spacing is measured from the wheel mounting surface to the innermost edge of the wheel rim. The dimensions above INCLUDE the tire bulge, if any. Wheel size examples to be used as a rough guide:
7" wide with up to 41mm positive off-set
7.5" wide with up to 35mm positive off-set
8" wide with up to 28mm positive off-set Ryane Motorsports will not be held responsible for improper wheel fit. The combination of wheel rim off-set and width will directly affect the tire/ fender clearance. Please keep this in mind when ordering our steering knuckles to fit with your existing wheels or if ordering new wheels to fit with our steering knuckles.
[Modified by eraser, 9:03 AM 12/24/2001]
Old Dec 24, 2001 | 12:32 AM
The knuckle gets in the way of any rim smaller than 15......
Id much rather have the drop forks...but how the hell can you get them??
alex1321
Apr 12, 2013 07:45 AM
whiteguyndahood
Dec 30, 2006 10:37 AM
Extreez
Oct 6, 2006 07:40 AM
Shiro Z31-T
Suspension & Brakes
13
Apr 22, 2005 07:26 PM
CTL
Mar 21, 2004 02:03 PM
