they dont make azenis in my size, whats a decent tire???
i need a set of 205/45/16's. i wanted azenis but they dont make my size it appears. what is decent tire for the money i can get?? this will be going on a civic hatch, if there is a size that will fit without rubbing let me know it will be lowered eventually about 1.5 inches. i can get 215/45's or 205/55's will either work??? ive always run 17's or 18's so i dont know
Landon
Landon
You could try the Hankook K104.
http://www.hankooktireusa.com/pdf/uploads/K104.pdf
Your size is on their list. I have driven some 240s with them and I was very happy with them.
what kind of drivign do u do?
autox??
just street?
for street try some yoko es100 or toyo proxes
for soemthing cheap but still direction radial try to find some avons there CHEAP and last long time
autox??
just street?
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
go with 215/45/16. ideally, 215/40/16 is closer to the stock diameter, but the 45 profile will do.
stan
stan
you can go with either 215 40 16 or 205 45 16. i've used both and both are good. you won't have a problem with rubbing if you're only lowering 1.5"
