d series tranny clutch interchangibility
Old Nov 1, 2004 | 09:17 PM
dstudent's Avatar
Default d series tranny clutch interchangibility
I went to purchase a clutch kit for my 89 Si Hatch and they show a listing for the 89 by itself . Im gonna be using a CRX si tranny instead of my Civic tranny. Are all the clutches interchangeable from 88-91>? Or is the 89 really different. Need to know ASAP...
Old Nov 2, 2004 | 06:54 AM
jlicrx's Avatar
Default Re: d series tranny clutch interchangibility (dstudent)
if the CRX transmission is not from 88, you need 89 clutch - if it is 88, you need 88 clutch - 88 and 89 Si used 200mm clutch - 90-91 used 212mm clutch - 88 has different spline count from 89-91 - 90-91 clutch will not bolt to 88-89 flywheel
Old Nov 2, 2004 | 07:18 AM
92integra_gs's Avatar
Default Re: d series tranny clutch interchangibility (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">if the CRX transmission is not from 88, you need 89 clutch - if it is 88, you need 88 clutch - 88 and 89 Si used 200mm clutch - 90-91 used 212mm clutch - 88 has different spline count from 89-91 - 90-91 clutch will not bolt to 88-89 flywheel </TD></TR></TABLE>
everything else is true except the flywheel...
88 tranny smaller PP smaller flywheel diffrent spline count from 89-91.
89 tranny same PP same flywheel as 88 but same spline count as 90-91.
90-91 bigger PP bigger flywheel same spline count as 89.
so for an 88 you need 88 disk 88 or 89 pp and flywheel or you can upgrade to the 90-91 bigger pp and flywheel but you need the lude disk as posted above.
*89 you need 89 disk, 88 or 89 pp and flywheel or you can upgrade to 90-91 disk and pp and flywheel.
90-91 you use 90-91 disk pp and flywheel or if your in a bind you can use the 89 disk pp and flywheel.
(note: some people have upgraded there disk, pp , and flywheel to the 92-95 civics the flywheel is 2-4 lbs lighter than 89-91 flywheels)
88 is a 21 spline
89+ is a 20 spline
84-87 Prelude 2.0 liter disc is 21 spline, 212mm
Modified by 92integra_gs at 10:30 AM 11/2/2004
Old Nov 2, 2004 | 07:28 AM
jlicrx's Avatar
Default Re: d series tranny clutch interchangibility (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">
everything else is true except the flywheel... 89-91 flywheel will bolt on any year except 88... how i know i have done it... the size done matter its the bolt pattern </TD></TR></TABLE>all 88-00 flywheels will bolt onto any D-series engine and have the same bolt pattern - the 88-89 use a smaller diameter clutch - 90-00 use the larger clutch - 90-00 clutch will not bolt to 88-89 flywheel as the pressure plate mounting bolt circle is larger
Old Nov 2, 2004 | 09:06 AM
alexsracing's Avatar
can a 88-89 200mm clutch disk fit in a 88 hf pressure plate? on a 88-89 flywheel
aj_zo
Jun 15, 2006 08:04 AM
swappedb16teg
Mar 22, 2005 08:01 PM
sykohatch
Aug 16, 2004 08:51 PM
Happyman
Jul 1, 2004 09:37 AM
mugensport9
10
Sep 23, 2003 09:01 PM
