removing cam gears without impact wrench
Old Dec 21, 2001 | 07:16 PM
shingles's Avatar
Default removing cam gears without impact wrench
Any suggestions on how to remove the cam gears without and impact wrench? Is there a way to 'lock' down the cams so I can torque the bolts off?
thanks!
-shing
Old Dec 21, 2001 | 08:01 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: removing cam gears without impact wrench (shingles)
remove valve cover, remove one cam cap on each cam. Use a piece of a buisness card between the cam cap and cam, tighten down the cam. Now slip off timing belt and do the gears.
The thin paperboard will lock the cams in place, just remember to take it back out!
Old Dec 21, 2001 | 08:52 PM
shingles's Avatar
Default Re: removing cam gears without impact wrench (Mista Bone)
ahh ok, sounds good. I shall give it a shot tomorrow.
thanks
-Shing
Old Dec 22, 2001 | 05:13 PM
fixhondas's Avatar
or with the Tbelt still installed- slip a long 12mm boxwrench on the bolt and smack it with your hand- or get some 20" "channel locks" and cut a piec of tbelt to put over the cam sprocket teeth, grip it with the locks and use a wrench to loosen.
Old Dec 23, 2001 | 08:51 AM
siisgood00's Avatar
New User
Default Re: removing cam gears without impact wrench (fixhondas)
You guys are crazy. Just take off the VC, timing belt and then stick a small allen wrench size object in the hole of the cam cover. This holds the cam from moving when messing with the gears. (make sure motor is at TDC) Works like a charm. Also, if no one has installed cams or gears on the car previously, (factory torque) then they can easily be taken off without an impact.
Old Dec 23, 2001 | 09:11 AM
non-VTEC's Avatar
Default Re: removing cam gears without impact wrench (siisgood00)
that is the correct way of doing it. that small hole is used for that exact reason. i belive a 8mm pin/drill bit/allen key will do the trick.
Old Dec 23, 2001 | 01:34 PM
BreakStuff's Avatar
New User
Default Re: removing cam gears without impact wrench (non-VTEC)
hmmm... not all cams have these holes guys...
Old Dec 23, 2001 | 02:09 PM
boosted3g's Avatar
Default Re: removing cam gears without impact wrench (BreakStuff)
Why not just break it loose with the timing belt still on. I cant imagine it turning the whole engine over. But then again i have holes in mine so im just taking a stab at it.
Old Dec 23, 2001 | 02:14 PM
BreakStuff's Avatar
New User
Default Re: removing cam gears without impact wrench (boosted3g)
Works for me!
me neither!
Old Dec 23, 2001 | 05:06 PM
fixhondas's Avatar
I STRONGLY DO NOT recommend holding the cam steady with the hole/pin method if you are removing the bolt- you WILL break the #1 cam journal(s). For belt replacement- it is fine and helpful- but for removing cam gears it is a big no no. The aluminum is not strong enough to hold the cam during bolt removal. Usually the little tab with the hole will break off- or the whole cap will break. I have seen this happen a few times- just loosen and tighten with the tbelt on- works for me.
[Modified by fixhondas, 9:08 PM 12/23/2001]
Old Dec 24, 2001 | 04:45 AM
Akira-R's Avatar
I usually just put a socket wrench on the crank pulley and turn it till it wedges.
Then it'll hold in place while you loosen then cam gear bolt.
--reid
Tram
Oct 26, 2013 06:04 PM
Blusol93
Nov 23, 2005 08:03 AM
LODOSS
Dec 31, 2003 03:56 AM
MaxSterling
Jul 11, 2003 04:16 PM
fastludeh22
Nov 20, 2002 07:38 PM
