adding KNOCK SENSOR to sensorless SOHC block- HELP!!!
Old Nov 1, 2004 | 07:10 PM
builthatch's Avatar
MiG-21 superfan
Default adding KNOCK SENSOR to sensorless SOHC block- HELP!!!
set up a friend with an Apexi PowerFC on a setup identical to mine, 'cept his uses a z6 block with no KS, and the PowerFC has a nice Knock Sensor monitor...any ideas here? i saw some stuff about LS/vtec adding the KS to the alternator bracket where it screws into the blizzock, however, i would like SOHC experience with this if anyone has that-
THANKS!
Old Nov 1, 2004 | 11:55 PM
Nerologic's Avatar
Default Re: adding KNOCK SENSOR to sensorless SOHC block- HELP!!! (builthatch)
i added a obd0 fan switch to a 93 block a while ago..
the back of the block already had a spot for some sensor, it was just a flat circular surface i just dilled it out to get to teh coolent jacket.
i tapped it and put in the sensor, only to find out it didnt seat right and started to leak coolent. I then had to pull it back out slip it back in with gobs of good ol JB weld and then i just generously put JB weld around the sensor.
its held up 15k miles later, so i think its an easy thing to do.
what your doing is basicaly similar to my experiance so it should be quite easy (minus the JB weld part )...
eddisgetti1
Nov 12, 2011 09:45 PM
bb6guy
Oct 25, 2010 04:27 PM
abbas
May 2, 2005 02:23 PM
BoostedD15B7
Jan 18, 2004 09:01 AM
black-hatch
Jan 5, 2003 01:17 PM
