benefit from taller slicks???
Old Nov 1, 2004 | 06:53 PM
turbociv's Avatar
Default benefit from taller slicks???
well, my setup is a lsvtec with about 190whp through 2 1/4 exhaust and about 132tq. I am currently running 20x8x13 slicks. Im manageing alot of 1.8-1.9 60fts and a few 1.7's. Now Im running a 92-93 gsr ys1 cable tranny with lsd. I am running around 13.1 at 90-100% humidity and 102-103 mph. heres one of my slips:
60ft......1.808
330......5.377
1/8......8.362
mph......82.23
1000.....10.954
1/4........13.156
mph......101.41
My car is a 89civic si with about 100lbs weight reduction. Could I hit 12's with a different size slicks. IM sure I coulda hit 12's with better weather and more seat time/practice but I just dont get that kind of oppertunities. Well, what size could you guys recommend and why???
thanks
john d
Old Nov 1, 2004 | 07:00 PM
TEAMGENDAI's Avatar
Default Re: benefit from taller slicks??? (turbociv)
Your times look good. The only tire size i would recommend would be 22-8-13. But it depends how high you rev this engine and what gear you are ending in the 1/4 mile. Keep up the good work!!
Old Nov 1, 2004 | 07:04 PM
turbociv's Avatar
thanks for the good words.
I try not to rev over 86-8800 rpms to stay in my power band but I find my self bouncing limiter in 4th gear (9100) right around the 1/4mi mark.
Old Nov 2, 2004 | 12:46 PM
turbociv's Avatar
bump for some more info.
Old Nov 2, 2004 | 01:05 PM
turbo*s2k's Avatar
Default Re: benefit from taller slicks??? (TEAMGENDAI)
Go with the 22x8-13. That should solve your problem ending the quarter mile in 4th at 9100rpms.
It helped when I went from 22x8-13" slick to a 24.5".
Good luck, good times!
Old Nov 2, 2004 | 03:17 PM
bluebird's Avatar
Default Re: benefit from taller slicks??? (TurboChrgd_Civic)
My friends b20vtec only dynoed at 141 whp.. On a 4th gear pull ..which does make a difference.. 24.5 inch slicks with about 200lbs of weight reduction... went 12.9 at 103 mph at pomona,ca...1.7 60ft time
Old Nov 4, 2004 | 06:13 PM
turbociv's Avatar
Default Re: benefit from taller slicks??? (bluebird)
those are some good times for such little power and not really alot of weight reductions. You sure about that????? sigh, I can only think of 1 day when the humidity was around 35% but I couldnt get to the track cause of work. My goal was 12's this season and now there calling for snow tommorow.
Old Nov 5, 2004 | 01:24 PM
prestonpark's Avatar
i dyno at 191 and 132 i hit 12.7 at 105 on 23 inch slick this is a jdm itr motor 98 spec
run open header
Old Nov 5, 2004 | 02:26 PM
msmotorsports's Avatar
The absolute biggest I would go would be 24.5" it would help with 60' and you would MPH better. However you will end up crossing the line around 7000K compared to your redline as it is now.
Old Nov 5, 2004 | 09:24 PM
bluebird's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv &raquo;</TD></TR><TR><TD CLASS="quote">those are some good times for such little power and not really alot of weight reductions. You sure about that????? sigh, I can only think of 1 day when the humidity was around 35% but I couldnt get to the track cause of work. My goal was 12's this season and now there calling for snow tommorow.
I would post the timeslips but I dont know how to post pics... but I would not lie!!! I said it was a 4th gear pull on the dyno.... 3rd gear dyno would probably render 15 more hp
Old Nov 6, 2004 | 04:27 AM
turbociv's Avatar
I dont doubt the times. Very impressive. Soo far I have people telling me to run 22,23,24.5 biggest. Hmmmm, well I definately want to pick the best size slick for my set up. How much of a difference would these different sizes make from each other.
Old Nov 6, 2004 | 05:03 AM
sloanrad's Avatar
Default Re: (turbociv)
go check this out, i use it alot to base gear ratio's and tire size.
http://www.housemanautosport.com/index.htm
Old Nov 6, 2004 | 05:41 AM
turbociv's Avatar
Default Re: (sloanrad)
nice. But Im not sure I understand what shift rpm is? Thats obviously not what I shift at sooooo. Whats that stand for and how can I use this calculator to find out whats best for me? Obviously the more mph the better time but, I dont want to get the biggest slick and then overdo myself. And run worse times.
also according to the calculator I should be around 110 at 4gear redline wich isnt what Im at. Im around 105mph. hmmmm.
Actually when I use a 4.785 fd for my equation its pretty accurate, But I have a ys1 gsr tranny.
do these specs look accurate for my tranny?
92-93 usdm gsr ys1
1st 3.307
2nd 2.105
3rd 1.458
4th 1.107
5th .880
fd 4.40
Modified by turbociv at 2:52 PM 11/6/2004
Modified by turbociv at 2:55 PM 11/6/2004
Old Nov 6, 2004 | 08:02 AM
sloanrad's Avatar
if you bump your revlimiter that may be slowing you down some. but this usuly figures right on for us. those ratios are b16 cable or type r. except 5th
b16hydro ---------------- b-series cable
3.23 1st ----------------- 3.166 1st
2.105 2nd ---------------- 2.052 2nd
1.458 3rd ---------------- 1.416 3rd
1.107 4th ------------------ 1.103 4th
0.848 5th ---------------- 0.87 5th
4.4 fd ---------------- 4.26 fd- i think some may have 4.4 not sure on the cable stuff.
also try gearing so that you go through the traps at peak hp. shift rpm is what your rpm falls down to coming into a gear. try to keep this just ahead of peak tourqe.
Modified by sloanrad at 11:14 AM 11/6/2004
TurboEG6262
Mar 2, 2013 03:19 PM
CHRIS S
Sep 10, 2009 09:32 AM
teefunk01
Feb 9, 2006 08:35 PM
londa hover
May 22, 2004 12:21 PM
HX_Guy
Jul 14, 2001 10:37 PM
