Progress Tie Bar+ CTR sway bar will it work?
Old Nov 1, 2004 | 05:05 PM
Halo's Avatar
Default Progress Tie Bar+ CTR sway bar will it work?
Just like the title says..Progress rear swaybars and exhaust just don't mix..Also how many of you are running just the ctr sway with no reinforcement? I am really paranoid about tearout, since that's what happend to my EK and let me say it was not fun
Old Nov 1, 2004 | 05:22 PM
Halo's Avatar
Default Re: Progress Tie Bar+ CTR sway bar will it work? (Halo)
Also does anyone know if the ctr has a different Ibeam structure than the usdm ep3?
Thanks in advance
Old Nov 5, 2004 | 11:20 AM
DC5ITR329's Avatar
Alot of people have the CTR rear sway running with no probs. If you go like 25+ then I would reenforce the chassis
Old Nov 5, 2004 | 06:56 PM
SoSoJeff's Avatar
Default Re: Progress Tie Bar+ CTR sway bar will it work? (aznbo1626)
it should...i had my progress sway temporarily removed but kept the tiebar and it worked fine
Old Nov 7, 2004 | 08:56 PM
ssmep3's Avatar
ive been running with my 22mm ctr sway for about 3 months with no issue. but i was also worried about tear out. but luckly i was at an event recently where a local show was doing some end of season clearance and got a DC sports rear tie for $80 but yeah, do the sway asap. its such a big defference handling wise. well worth the money.
Old Nov 7, 2004 | 09:26 PM
Halo's Avatar
Default Re: (ssmep3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssmep3 &raquo;</TD></TR><TR><TD CLASS="quote">ive been running with my 22mm ctr sway for about 3 months with no issue. but i was also worried about tear out. but luckly i was at an event recently where a local show was doing some end of season clearance and got a DC sports rear tie for $80 but yeah, do the sway asap. its such a big defference handling wise. well worth the money.</TD></TR></TABLE>
The progress bar is 25 mm I believe, so moving to a 22mm bar would theoretically be less stiff? Thoughts? I only want a different bend to avoid contact with the exhaust. Otherwise I love the progress keeps the back real tight, it's the rattle that is killing me
305civictyperaw
May 13, 2011 12:05 PM
titosek4
Suspension & Brakes
Apr 30, 2009 02:18 PM
Cboi
Mar 5, 2007 06:01 PM
elitesi8
27
Oct 25, 2006 01:56 AM
