kteller exhaust
Old Nov 1, 2004 | 05:03 PM
propwdialogue's Avatar
Default kteller exhaust
Working on my buddy's CRX and we're looking into buying the 2.25" weld on crx piping kit from kteller.com http://www.kteller.com/store/p...d/977
and probably going with a magnaflow muffler http://www.kteller.com/store/p.../1030.
has anyone used either and can i see pics/reviews/opinions? thanks in advance for your help
Old Nov 1, 2004 | 05:05 PM
drdisco69's Avatar
Default Re: kteller exhaust (propwdialogue)
to kteller. I have the 2.5" stainless for my crx, I'll be installing it soon. Very high quality. Everyone will tell you good stuff about kteller.
Old Nov 1, 2004 | 05:24 PM
Default Re: kteller exhaust (drdisco69)
howsabout a little write-up action on the install?
what muffler and/or resonator are you going to be running?
Old Nov 1, 2004 | 05:35 PM
drdisco69's Avatar
I'm using a Dynomax Ultraflow and a Thrush 28" resonator, courtesy of Jegs. This should give me a stock sound... most of the time. I have to cut the piping to fit the resonator (easier said than done) and have it welded. Everything they send slips together for easy welding, just line up the muffler with the pipes. The only thing I'm not sure about is the 2 flanges they sent, and where they go. I assume they go between the cat and the piping, but I guess they go where ever the hell I want them too.
I'll see about the write up, I've never been too good at that kind of thing, too busy installing, no time for pictures. I'll get some pics and video when it's done though.
Old Nov 1, 2004 | 05:43 PM
HatchBox's Avatar
Skoobie no more...
whats the diff between full kit and mid section kit?
worth the 185?
Old Nov 1, 2004 | 05:49 PM
d357r0y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">The only thing I'm not sure about is the 2 flanges they sent, and where they go. I assume they go between the cat and the piping, but I guess they go where ever the hell I want them too.</TD></TR></TABLE>
I think those flanges go near the axle so you can take apart the exhaust in the event you need to remove it. (OEM style)
Old Nov 1, 2004 | 06:10 PM
drdisco69's Avatar
Default Re: kteller exhaust (d357r0y)
I thought that too, but everything there slips together. I could cut and put it in, which I might do.
Old Nov 8, 2004 | 09:14 PM
KTeller8's Avatar
we have an install on the crx on the site
http://www.kteller.com/tech
go to the crx install link.. shows picture of how you can do the basic install..
this was added to our site after a customer put it on backwards
Old Nov 8, 2004 | 09:32 PM
BOSS-REX's Avatar
I just put a magnaflow cat back full exhaust system on my 88 si crx that has a sohv zc and what a differences. It hits the rev-limiter 7000 rpm allot faster than the stock pee shooter dose and the car accelerates faster between shifts.
Weeeeee get it done.
It sounds bitch-en too.
CRXguy_88
Jun 1, 2009 03:15 PM
gcturismo
Dec 2, 2007 02:48 PM
EF_ST@TUS
Nov 2, 2006 10:51 PM
cbp_crx
Jan 23, 2006 01:57 PM
TRE_
May 12, 2003 02:12 PM
