Doing 94 integra cluster swap in a 90 hatch
Old Nov 1, 2004 | 04:13 PM
HatchBox's Avatar
Skoobie no more...
Default Doing 94 integra cluster swap in a 90 hatch
have searched the web for like a hour and all these write ups are diff.
I cant find what pinout on the integra plugs is the coolant temp wire!!!
Look here.
Originally Posted by [url
http://www.angelfire.com/dc/oregonimport/gsr.html[/url]]
PIN 94-99 Integra COLOR FUNCTION 90-91 CIVIC/crx
Connector B / 16P
B1 Red/Blue Fuel gauge C710 #3 Yellow/white
B2 empty
B3 Yellow/Black Seat belt light Empty
B4 Green/Yellow Low fuel light Not used unless you use a 90-93 integra fuel level guage
B5 empty
B6 Orange Speedometer Splice in with signal from vss in the tranny
B7 Blue/Black Trunk/hatch open C710 #5 Green/Black
B8 empty
B9 Red Brightness C709 #9 Red/Black
B10 Red/Black Gauge lights C709 #8 Red
B11 Black/White color varies VSS Run the electronic Vss to here and also attach to the orange where b6 is ran..
B12 empty
B13 Green/Red-1 Silver Stripe Left turn signal C709 #12 Green/Blue
B14 Green/Yellow-1 Silver Stripe Right turn signal C710 #1 Green/Yellow
B15 Red/Green n/a not used
B16 Green/Red Emergency brake C709 #6 Green/Red
Connector C / 13P
C1 empty
C2 empty
C3 empty
C4 Yellow Dimmer C710 #2 Black/Yellow
C5 empty Cruise control empty
< C6 empty Empty empty
C7 Black Black Ground C710 #8 Black
c8 Yellow/green Brightness C709 #10 Yellow/Green
C9 White/Blue Battery C709 #2 White/Blue
C10 empty
C11 Yellow/Red Oil pressure C709 #5 Yellow/Red
C12 Green/Orange Check engine C709 #4 Green/Org
C13 Blue Tachometer C710 #2 Blue
http://www.geocities.com/Area51/Labyrinth/5039/gaugecluster.html[/url]]
B1
Yellow/White
Fuel Gauge
B1
Yellow/White
B2
Lt Green/Red
Door Open Indicator Light
B3
Empty
B4
Blue/White or Green/Yellow
Low Fuel Indicator Light
B5
Empty
B6
Orange
Speedometer
B2
Yellow/Blue
B7
Blue/Black or Green
Tailgate-Open Indicator Light
A2
Green
B8
Empty or Lt Green/Red
Seat Belt Reminder Light
A1
Blue/White
B9
Red
Dash Lights Brightness Controller
B12
Red
B10
Red/Black
Gauge Lights
B11
Red/Black
B11
Black/White
Vehicle Speed Sensor
B12
White/Green
Hazard Warning Light
Hazard Button
White/Green
B13
Green/Red or Green/Blue
Left Turn Signal Indicator Light
B4
Green/Blue
B14
Green/Yellow
Right Turn Signal Indicator Light
B3
Green/Yellow
B15
Red/Green
High Beam Indicator Light
A10
Red/Green
B16
Green/Red
Parking Brake Switch
A9
Green/Red
CONNECTOR D
13 PINS
D1
Pink
Hazard Warning Switch
D2
Pink
Maintenance Reminder Unit
D3
Empty
D4
Yellow/Blue
D5
Red/Blue
Cruise Light
D6
Black
Ground
A5
Black
D7
Yellow/Green
Engine Coolant Temperature
A4
D8
Empty
D9
White/Blue
Charging System Light/Power
A3
Yellow
D10
Empty
D11
Yellow/Red
Engine Oil Pressure
B6
Yellow/Red
D12
Green/Orange
Malfunction Indicator Light
A6
Green/Orange
D13
Blue
Tachometer
B8
Blue
Some say on the 13 pin 7 is coolant temp Some say 7 is ground. Some others are even diff.
PLEASE HELP!
Old Nov 1, 2004 | 04:59 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Doing 94 integra cluster swap in a 90 hatch (HatchBox)
Old Nov 1, 2004 | 06:45 PM
TIRENECK's Avatar
would like to know also.
Old Nov 1, 2004 | 06:50 PM
APEX CRX's Avatar
Default Re: Doing 94 integra cluster swap in a 90 hatch (TIRENECK)
bump, I'll be doing this cluster swap soon too.
Old Nov 1, 2004 | 06:54 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Doing 94 integra cluster swap in a 90 hatch (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">bump, I'll be doing this cluster swap soon too.</TD></TR></TABLE>
every thing was great then i got to this wire.
i also had trouble finding the 'cluster switched power' wires.
Old Nov 2, 2004 | 08:14 PM
HatchBox's Avatar
Skoobie no more...
Ok well i did some re-search.
Went on my schools computer 'shop key' by snap-on
lists every car how to fix them, wiring diagrams , blah blah blah.
well anyways here is what i got from that-
links:
http://www.imagestation.com/pi...8.jpg
http://www.imagestation.com/pi...f.jpg
You can see the differences in these.
My question is, should i go with how shop key tells me?
Old Nov 3, 2004 | 06:41 AM
HatchBox's Avatar
Skoobie no more...
afterdark
10
Feb 25, 2012 09:31 AM
bakoCRX
Jul 16, 2009 07:25 AM
quis84
Feb 7, 2006 10:14 AM
Gumbey75
Mar 25, 2005 08:20 PM
Turbo Powa
22
Jun 29, 2003 11:45 AM
