f-series come vtec?
Old Nov 1, 2004 | 01:38 PM
EKB18BPR3's Avatar
Default f-series come vtec?
my friend's gotta 94 accord lx and wants to know if he can do a vtec head swap on it. i told him i didnt know and that id ask u guys. dont flame...im a B-series guy. oh and i tried search but i didnt know his engine code. thanx and he appreiciates ur help guys.
Old Nov 1, 2004 | 01:41 PM
.bagged's Avatar
Default Re: f-series come vtec? (98B00STED)
You might wanna check the lude forum.. Its been done..
Lemme see if i can find the thread..
Old Nov 1, 2004 | 04:58 PM
jakeiscool's Avatar
Banned
Yes he has an f22b2 non-vtec motor. An h22 dohc vtec head works as does the much more common f22b1 vtec head.
Old Nov 1, 2004 | 05:20 PM
v4lu3s's Avatar
RTFM
the easisest way to do it is a drirect head swap of the ex head.
Old Nov 1, 2004 | 05:38 PM
Legendaryyaj's Avatar
Default Re: (v4lu3s)
Yes it can be done. He will need a f22b1/2(?) head.
Or
He can do this: https://honda-tech.com/zerothread?id=776837
Old Nov 1, 2004 | 07:14 PM
momstaxi's Avatar
yes, you can swap a f22b1 sohc vtec head on an f22b1 sohcnon-vtec block. I did it on my 95lx. it is a very simple and straight forward swap. all the components are identical. the same headgasket is used (vtec, non-vtec same gasket) you can use the same exhaust manifold. you can also use the same distributer. be sure to use the vtec timing belt though. on that note though, the difference between an f22b2 and a f22b1(vtec) is only 15hp and 7ft lbs, which some of that difference can be attributed to an ex models better exhaust design.
or, as others are saying an h series vtec head, but as you can see is a little more labor intensive.
Old Nov 1, 2004 | 09:51 PM
TOAB's Avatar
Default Re: f-series come vtec? (momstaxi)
as ive said in all the other threads that people have been making on this topic as of late... dont even bother.
hello_kitty5
Honda Civic (2001 - 2005)
Jan 12, 2013 06:49 PM
souljah07
May 18, 2007 05:41 AM
birdxa
Jan 10, 2005 08:31 PM
streetspeed607
Dec 7, 2004 10:56 PM
mason
Dec 11, 2001 02:33 AM
