88 crx hf axles in si tranny?
Yes, your axles will work fine.
As for the clutch, make sure to use a clutch for the year of the vehicle that the tranny came from. If it is an '88 trans, use an '88 clutch. If it is a '90-91 trans, use a '90-91 clutch.
If your chassis is a HF you will need to use HF axles. They go right in the trans no problem. HF's have smaller outer CV's so you have to use HF axles with HF hubs. If you chassis is a DX/SI will need DX/SI axles....
donaldmejr
Dec 13, 2005 05:48 PM
Nossy
10
May 4, 2002 10:00 AM
