crank sensor code = 3200 rpm rev limit help
have an 88 civic dx with an ls turbo my timing belt is dead on and my distributor is fully advanced and it still only fires at zero degrees every check I've done is with my multimeter so far my ecu is good and my distributor is good but I'm guessing the code is caused by the bad ignition timing? just looking for some thought on someone elses behalf please help
did you do the mpfi swap your self? if so make sure you have the b12 & b10 pins in the correct place and not up side down in b11......
ect
ect
1991ED6
Sep 7, 2012 08:49 PM
nayrone
Nov 1, 2004 12:09 PM
