Will crx taillights fit on Civic hb??
Yes, they should fit, but you will need to drill because the mounts are in different places on the CRX. Also, you'll notice on the CRX taillights, that the reverse lights are on the inside piece and not the two outside pieces the way the civics are. You may have trouble with the middle piece since the CRX middle piece is thicker than the civic's middle piece.
Just lookin to see if they would fit or not. Don't care about the center section. Will they line up to the body alright??
man you guys are way off the mark they dont fit, they arent even close, i have never tryed cause im no that stupid but the civic tails are straight and the crx are slanted inward at the top, you will also prolly have to do some bodywork to get them to fit and look right, but y would you want to.....??? the civic tails are fine...what do you want CRX altezzas or something....i hope not cause not only are they played out and ugly but they are cheaply made and fall apart easy....keep it stock and simple it will last longer
vtecn8ive
Jun 18, 2010 07:15 PM
89civicdx
Sep 5, 2008 08:21 PM
Sik Wit It Hatch
Jun 9, 2005 08:52 PM
