Where I could get this .... to make a new intake manifold.
Old Nov 1, 2004 | 07:35 AM
yellowturbo's Avatar
Default Where I could get this .... to make a new intake manifold.
Im refering to the kind of *horn* that you see... it looks like a kind of weber... sorry I dont know how to call this piece but I want to get 4 of them to make a new intake manifold !
Thanks !
Old Nov 1, 2004 | 08:43 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Where I could get this .... to make a new intake manifold. (yellowturbo)
I believe their called "velocity stacks" but I don't know where to get them.
Old Nov 1, 2004 | 08:47 AM
its a begining !! thanks ! now I need to know where I can get those velocity stacks .
Old Nov 1, 2004 | 09:14 AM
project dc2's Avatar
Default Re: (yellowturbo)
twm induction.
Old Nov 1, 2004 | 09:34 AM
sweeet thanks dude !
Old Nov 1, 2004 | 10:01 AM
wantboost's Avatar
Who is Mr Robot?
full-race has some as well if i'm not mistaken
Old Nov 1, 2004 | 10:04 AM
ZoRG's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">full-race has some as well if i'm not mistaken</TD></TR></TABLE>
They don't use Velocity stacks as far as I can tell, either way, doubtfull they will sell their stuff seperate. It's worth more assembled.
Old Nov 1, 2004 | 10:21 AM
.nate's Avatar
Buy a VW mag. They have craploads of velocity stacks...
Old Nov 1, 2004 | 11:00 AM
ok thanks for all your reply!! keep them coming !
Old Nov 1, 2004 | 05:30 PM
GT61 this 1.8t's Avatar
Default Re: (ZoRG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZoRG &raquo;</TD></TR><TR><TD CLASS="quote">
They don't use Velocity stacks as far as I can tell, either way, doubtfull they will sell their stuff seperate. It's worth more assembled.</TD></TR></TABLE>
do what?!?!
i noticed you posted in the full-race intake manifold post... figured you would have been up to date... they will be running stacks.
Old Nov 1, 2004 | 08:38 PM
FastEK9's Avatar
Default Re: (GT61 this 1.8t)
kingsler sells em.
Old Nov 2, 2004 | 06:53 AM
MrCivic03's Avatar
Default Re: (FastEK9)
jc whitney does too i thought....
Old Nov 2, 2004 | 05:40 PM
rexsk8er's Avatar
so what length and diamater intake runners are you going to use? have you researched into it any?
Sean
Old Nov 2, 2004 | 06:00 PM
HeikDiesel's Avatar
Default Re: Where I could get this .... to make a new intake manifold. (rexsk8er)
Looks to me like that manifold is attached to some itb's. What are you making this manifold for anyhow? Only reason I could see for this would be a forced induction application on a itb'ed car
Old Nov 2, 2004 | 07:10 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Where I could get this .... to make a new intake manifold. (PhatAcuraIntegra)
there are a lot of manifolds out there that use velocity stacks in the plenum with a single tb. veilside uses it on their 2jz mani, str and venom have them on theirs.
Old Nov 2, 2004 | 08:16 PM
HeikDiesel's Avatar
Default Re: Where I could get this .... to make a new intake manifold. (wantboost)
really...I did not know that. I would think that although you are using a velocity stack which would be good for air turbulence, that the lip of the stack would do more harm than help
Old Nov 3, 2004 | 03:31 PM
x20vmk4x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Looks to me like that manifold is attached to some itb's. What are you making this manifold for anyhow? Only reason I could see for this would be a forced induction application on a itb'ed car</TD></TR></TABLE>
single tb, a place called momentum made the manifold for him. vw envy, eh
Old Nov 3, 2004 | 04:20 PM
hotrex's Avatar
Default Re: Where I could get this .... to make a new intake manifold. (x20vmk4x)
my venom manifold did not have velocity stacks.
Old Nov 3, 2004 | 04:26 PM
HeikDiesel's Avatar
huh? Spaek english
Old Nov 3, 2004 | 05:20 PM
turbo gli's Avatar
http://www.eurospeed.ca/performance/index.htm scroll down a bit .. 55 for the long ones or 30 for some shorites .. these and tws induction has them .. or hit up ebay
Old Nov 3, 2004 | 06:20 PM
x20vmk4x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">huh? Spaek english</TD></TR></TABLE>
which part didnt you understand?
a)
"single tb"
or
b)
"a place called momentum made it for him"
comprehend much? and learn to spell.
kthx
Old Nov 3, 2004 | 06:25 PM
snoochtodanooch's Avatar
what are the advantages of using these guys. It seems like it crowds some volume out of the intake, but aren't they supposed to make the air swirl better or something, i am just curious. Probably adds more toque if anything, nice clean entrance into a long body. Just curious questions.
Old Nov 4, 2004 | 02:43 PM
red92si's Avatar
The benefit of velocity stacks is that they are wider at the top of the horn and gradually get slimmer as they get to the bottom of the stack where they would attach to the rest of the manifold. This gradual decrease in the inside diameter forces the intake air's velocity to increase, thus causing the fuel and air to mix together more completely and achieve better atomization.
Old Nov 4, 2004 | 02:47 PM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x20vmk4x &raquo;</TD></TR><TR><TD CLASS="quote">
a)
"single tb"
or
b)
kthx</TD></TR></TABLE>
I was actually talkin about the VW envy part? What does that have to do with anything. And thanks N00bie, I can spell
Old Nov 6, 2004 | 02:33 AM
TurboEH2's Avatar
they are velocity stacks and http://www.summitracing.com
