Have question about 88 CRX suspension
Old Oct 31, 2004 | 11:21 PM
supersi88's Avatar
Default Have question about 88 CRX suspension
I recently bought new monroe struts and adjustable coilover springs for my 88 CRX. When I installed them in the car, the top of the strut piston rod was sticking out above where it was suppossed to rest inside the engine compartment. My friend says that I need to have the top of the strut machined so that the threads go further down the piston rod, but unless I can figure out what to do, I think I might just go back to stock springs. Any suggestions about what to do would be appreciated. Thanks.
Old Oct 31, 2004 | 11:47 PM
Tyson's Avatar
Default Re: Have question about 88 CRX suspension (supersi88)
you forgot the big thick washer thats supposed to slip on the top of the rod, then you slide it into the bushing/top hat.
Old Nov 1, 2004 | 12:33 AM
hondacrx03's Avatar
Default Re: Have question about 88 CRX suspension (Tyson)
most likly u just need the washers to get it at the rite higth
Old Nov 1, 2004 | 01:29 AM
PissedoffGS-R's Avatar
Default Re: Have question about 88 CRX suspension (hondacrx03)
If it means so little to you that your cars lower that you would be willing to call it all of for such a simple thing you should probably just leave it stock, i think you will be a more happy person in the long and short run.
Old Nov 1, 2004 | 12:45 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">you forgot the big thick washer thats supposed to slip on the top of the rod, then you slide it into the bushing/top hat.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1040017
primetimedx
Jun 8, 2006 10:04 PM
xx89civicracer89xx
May 22, 2006 03:21 PM
02_IT-S
Suspension & Brakes
Oct 3, 2005 02:06 PM
supersi88
Oct 30, 2004 10:49 PM
Combustion Contraption
Oct 26, 2003 03:05 PM
