87 civic fuel dump
Old Oct 31, 2004 | 06:16 PM
Ricky26's Avatar
Default 87 civic fuel dump
Pleeze help. My 87 civic rebuild ran great for 6 mos. Now, everytime I try to get it started, the compression goes way up... and the dipstick is 50/50 oil & fuel mixture. Changed out the carb. with a junkyard dog, changed the oil, reset the air/fuel and idle adjust screws & checked vacuum lines... Again, the compression and fuel/oil mix problem. Dun it 6-8 times.
Old Oct 31, 2004 | 10:33 PM
drussell4801's Avatar
Default Re: 87 civic fuel dump (Ricky26)
if you're saying that you have 50% fuel in your crankcase oil, then your rings are fucked.
if you're saying something that has to do with carburetors, then I have no ******* clue.
Old Nov 1, 2004 | 08:21 AM
dr_latino999's Avatar
Default Re: 87 civic fuel dump (drussell4801)
I would second the ring motion, but for the fact that the compression numbers go up I think it is something else. What it is, I have no clue.
Old Nov 1, 2004 | 09:37 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: 87 civic fuel dump (dr_latino999)
For those not familiar with the 87 carbed engines, your fuel pump is mounted on the distributor end of the head. The diaphram in yours has a leak, which is pumping fuel into the head which drains down into the oil pan. Replace your fuel pump and your problem will be solved.
Also, *exactly* what do you mean by "everytime I try to get it started, the compression goes way up"? Please be specific.
backstrap1
Honda S2000
Mar 22, 2010 06:32 PM
2oh6civic
Sep 7, 2007 11:49 AM
DaveF
Jul 30, 2004 07:10 AM
siis2fast
Jun 3, 2004 10:12 PM
myhatchrips
Mar 1, 2003 05:12 PM
