Rubber Door Trim RIpping
Anyone else have this? Moulding along vertical rear edgeis ripping on both sides about 6" above the door. My doors need to be realigned too I think........
some times mine stick a little and I gotta give the door a tug.. but no ripping.. but I dont like smacking them against guardrails, so my doors are still aligned!
Yea mine stick too, like it seals too tight..... the dealer told me to spray WD-40 on it........ I really don't care for that on my paint, thanks
at times my door sticks also but it doesn't matter what temperature it is outside... but when i put force upwards and then open it....it opens smoothly, does this mean my doors are not aligned. i used silicon, worked for about a few hours. i guess it's not aligned huh?
My '98 ITR did the same thing on the driver side. After a little while the same rubber piece you mentioned started to rip. Took it in for warranty work and everything is good now.
-kenji
-kenji
Bringing this one back from the dead....anyone found a solution besides from using silicon spray? I have the same problem with mine but using silicon spray can get messy on clothes and such.
Thanks.
Thanks.
