11.9@125 on yokohama advans *vid inside*
Old Oct 31, 2004 | 03:44 PM
gsrmattski
Guest
Posts: n/a
Default 11.9@125 on yokohama advans *vid inside*
i went to the track today, when i got there it looked like it was about to rain any second, and i wanted to get at least one pass in, so i did a pass on the same tires i drove to the track on (yokohama advans A032R - 205/50/15)
btw my car is full weight, full interior, daily driven street car, driven at the track like its driven on the street
heres the video
http://we-todd-did-racing.com/...DE%3D
i then put some 22" slicks on and made another pass
http://publish.uwo.ca/~cdaley3/gsrmatt2.wmv
the 11.9 pass was on the advans
the 11.4 pass was on the 22" slicks
after that second pass, i got kicked off the track for not having a roll cage
EDIT - second vid should work now
Modified by gsrmattski at 3:39 PM 11/1/2004
Modified by gsrmattski at 3:40 PM 11/1/2004
Old Nov 1, 2004 | 03:07 AM
Casey's Avatar
Default Re: 11.9@125 on yokohama advans *vid inside* (gsrmattski)
good runs whats your setup/dyno numbers?
Old Nov 1, 2004 | 05:13 AM
95VXB16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">good runs whats your setup/dyno numbers?</TD></TR></TABLE>
I 2nd that motion.
Old Nov 1, 2004 | 06:11 AM
91tegrals's Avatar
man that second video cuts out at about mid track so did the mustang beat you or wat..
Old Nov 1, 2004 | 06:15 AM
Turbocivic94's Avatar
Default Re: (91tegrals)
Nice times
Old Nov 1, 2004 | 06:48 AM
gsrmattski
Guest
Posts: n/a
Default Re: (Turbocivic94)
thanks!
the second vid should work now
Old Nov 1, 2004 | 02:02 PM
Honda Sport's Avatar
good runs. what's your setup? so if you ran at the track what you usually run on the streets, that means you run open exhaust all the time? cause it sure sounded like you you running no exhaust at all.
Old Nov 1, 2004 | 02:10 PM
radeon's Avatar
N/a or turbo?
Old Nov 1, 2004 | 02:24 PM
gsrmattski
Guest
Posts: n/a
Default Re: (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">good runs. what's your setup? so if you ran at the track what you usually run on the streets, that means you run open exhaust all the time? cause it sure sounded like you you running no exhaust at all.</TD></TR></TABLE>
my setup is built b18c1 block with stock type r head
SC61 turbo running 20lbs on pump gas
417whp/293tq
and i ran the car with full exhaust, as can be seen in the 2nd video
those 2 passes are the first and only 2 passes i have done at the track since going turbo.
next time i goto the track i think ill test out some 225/50/15 bfg drag radials or something, see if i can get any better, altho i think i could have got my street tire time down if i had the chance to do more runs on the yokohama advans.
Old Nov 1, 2004 | 02:46 PM
905_Legend's Avatar
Default Re: (gsrmattski)
Nice times
Hope to see your car next summer at the track.
Old Nov 1, 2004 | 03:41 PM
bluebird's Avatar
Default Re: (905_Legend)
sweet run!! Why does your timeslips have two different #'s????? :
Old Nov 1, 2004 | 04:37 PM
gsrmattski
Guest
Posts: n/a
Default Re: (bluebird)
because the monkey in the tower didnt type them in right.
if you have any doubts, watch the videos..
Old Nov 1, 2004 | 04:39 PM
mc55's Avatar
Wow, your car is hauling *** man. You said you were going to do it, and you did, congrat's.
Old Nov 1, 2004 | 05:09 PM
bluebird's Avatar
No doubt I seen them.. Just wondering!!!!
Old Nov 4, 2004 | 04:15 AM
PA Geesir's Avatar
fast
Old Nov 4, 2004 | 04:23 AM
sircrxracer's Avatar
Nice Matt..... that thing is fast what tranny did you end up with after NCRA? Rob
Old Nov 4, 2004 | 08:16 AM
gsrmattski
Guest
Posts: n/a
Default Re: (sircrxracer)
i thought it was the dif that broke at ncra, but it turned out it was just a shaft, so im still using the same ITR tranny
ls2000
Sep 28, 2010 06:37 AM
HamiltonRex
Sep 13, 2010 09:49 PM
bb_one
Nov 25, 2007 07:54 PM
jjspec
Sep 2, 2007 05:17 PM
