Distributor to cylinder plud wire order B16 Crx
Old Oct 31, 2004 | 02:43 PM
calgone47's Avatar
Default Distributor to cylinder plug wire order B16 Crx
Does anyone have that picture that showed EXACTLY which plug went from where on the dizzy to which cylinder?? I think I ready the GSR Haynes manual wrong and burned up my distributor, dont want it to happen again!! Already searched, couldn't find the picture anywhere...
Thanks in advanced
Modified by calgone47 at 7:25 PM 10/31/2004
Old Oct 31, 2004 | 04:03 PM
calgone47's Avatar
bump please help!!
Old Oct 31, 2004 | 04:52 PM
RC000E's Avatar
Default Re: (calgone47)
Putting your plug wires in the wrong order won't cause anything in your distributor to burn up. The firing order is 1-3-4-2 in a counterclockwise rotation when facing the cam gears, therefore when facing the distributor starting at the lower left you put the number 1 plug wire, then above that number 3, then beside that number 4, then below that number 2. As a result, when the motor turns in its direction of rotaion the rotor will contact and send spark to 1, then 3, then 4, then 2. Simple concept if you would just think bro.
Old Oct 31, 2004 | 05:25 PM
CRX_Control's Avatar
Default Re: (RC000E)
http://img18.exs.cx/img18/7701/b16firingorder2.jpg
jdmeg21
Oct 18, 2009 04:18 PM
urtz
Nov 29, 2006 07:28 PM
h22a_junkie
Apr 11, 2006 08:49 PM
zc_crx
Jan 4, 2006 04:06 PM
VTcivicEG
Sep 1, 2004 01:13 PM
