'94 Accord EX - Can anyone help ?
Old Oct 31, 2004 | 11:28 AM
Tenners's Avatar
Default '94 Accord EX - Can anyone help ?
I am the proud owner of a 1994 Accord. It's an EX model (don't know if that makes any difference with these problems here) and it's also a manual. The mileage is pretty high (about 214K) and I'm having a couple problems.
1. When my rpm is low...not too low...say around 1000-1500 RPM, and I'm in a low gear, I get a
shudder and my entire dash shakes pretty bad. It's as though I'm not balancing the clutch but
I don't think that's it cause i've been drivin' stick since i was 14 years old.
The balance point is soooo very precise and I was wondering if this has anything to do with the
clutch plate.
2. An old lady hit the front of my car the other day...ever so slightly....not even much paint
damage. Anyway, now, when my cooling fan comes on it sounds like a card stuck in a bicycle's
spokes when you're riding.
I checked it out and it seems as though the edge of the blades are touching the engine mount.
I don't know how this could have happened since there doesn't seem to be any sort of damage
to the radiator, radiator mounts or metal that the radiator and fan are hooked up to.
Nothing bent or broken.
Any ideas on how this could have shifted back 1/8 of an inch?
Where should I look and for what should I look in order to resolve this noisy matter?
Thanks,
Tenners.
Old Oct 31, 2004 | 12:21 PM
KatyHonda's Avatar
Default Re: '94 Accord EX - Can anyone help ? (Tenners)
Shudder sounds like clutch grab, which happens as the clutch ages. Start saving for a new clutch and pressure plate.
Impact may have been more than you think. I don't see how the fan shroud could have been bent otherwise. Removing the fan assembly is straightforward, although it can be challenging to get to the lower bolt that retains the lower fan shroud support. You only need to loosen, not remove. You'll need to remove the dust shield for access and still the bolt can be tough to loosen. A long open end or offset closed end 10mm wrench can help.
You may have a worn out fan and the blade is wobbling due to worn out bearing. Check ebay for a new or used fan motor.
good luck
Old Nov 1, 2004 | 08:35 AM
Tenners's Avatar
Default Re: '94 Accord EX - Can anyone help ? (KatyHonda)
Thanks a lot,
I figured as much...with the clutch I mean.
I'll see what I can do about the fan situation as well.
Thanks for your help KatyHonda!
Old Nov 2, 2004 | 08:38 AM
Elkins911's Avatar
if you wannt get rid of your rear bumper ill take it, you should part the car out with such high miles on it... then buy a new one!
Old Nov 2, 2004 | 08:46 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: '94 Accord EX - Can anyone help ? (Elkins911)
seems like you really need a rear bumper, seen you post "Ill take your rear bumper" in a couple threads now. Why do you need a bumper so bad? You should also add that to you sig, you only have the rear lip listed.
deathdealer757
May 17, 2009 07:52 PM
bucclao
Jan 9, 2007 05:25 PM
Accord Driver
Jul 18, 2003 09:26 AM
