97 Accord Gas Mileage
Old Oct 31, 2004 | 10:22 AM
alfer's Avatar
Default 97 Accord Gas Mileage
I have a 97 Accord EX V6 and I was originally able to get 23-25 miles per gallon out of it. Recently I started getting around 13 and with gas prices the way they are im wondering what might cause this. I already checked the air filter which is squeaky clean and Ill probably pull a couple spark plugs also. Is there anything else it could be?
Old Oct 31, 2004 | 11:20 AM
FatJoe's Avatar
Default Re: 97 Accord Gas Mileage (alfer)
o2 sensor is prolly your culprit.... check it out and see if its bad....ur not throwin any CELs are you?
Old Nov 1, 2004 | 07:00 AM
SIMATIC's Avatar
Default Re: 97 Accord Gas Mileage (FatJoe)
yea mine to, like 13-14 mpg u think its the o2 sensor?
Old Nov 3, 2004 | 11:13 AM
alfer's Avatar
Yeah no engine lights at all which is why i didnt suspect the o2 sensor. Is it possible the ecu would not detect it even though it is faulty? Thanks for the info,
aLfer
Old Nov 5, 2004 | 11:57 AM
alfer's Avatar
Seems like the O2 sensor is producing correct output. Anything else anyone can think of?
Old Nov 5, 2004 | 01:52 PM
elmitols's Avatar
If you engine surges, it could be the MAP sensor. Sometimes the computer doesn't pick it up, it should. Far shot, but it may be a faulty computer.
Old Nov 29, 2004 | 04:56 PM
alfer's Avatar
Default Re: 97 Accord Gas Mileage (elmitols)
Well this is interesting. The 13 to the gallon im getting happens only when driving around town. I took a trip last weekend and got 24 travelling almost exclusively by freeway. Even before, around town I would get around 19-20. I live in a small town and never drive more than a couple of miles. Anybody have any other suggestions?
Old Nov 29, 2004 | 06:58 PM
Charri's Avatar
Continuous short trips with cold starts?
Old Nov 29, 2004 | 09:08 PM
he_man's Avatar
had a frend who had the same problem...he changed his o2 sensor...but wasnt that...heard from a buddy to try reseting the ecu on is car...that worked....might want to try that....
Old Nov 29, 2004 | 09:40 PM
alfer's Avatar
Default Re: 97 Accord Gas Mileage (he_man)
ill try that. Whats the best way to fully reset the ecu?
Old Nov 30, 2004 | 12:25 AM
Charri's Avatar
Take battery off for 15 minutes or take off the negative terminal for 15 minutes. Will have to input radio code after you restart ECU.
jentee
Jun 8, 2008 11:01 PM
ProLineDesigns
Jan 17, 2007 04:30 PM
lax1089
Dec 11, 2006 11:27 AM
hldurham
Apr 7, 2006 12:00 PM
Nizzy
May 22, 2003 03:58 PM
