accord 95 check engine
Old Dec 21, 2001 | 09:35 AM
ashish_bhatta's Avatar
Default accord 95 check engine
i have noticed that when i start my car in the morning and as soon as i reach 30m/h the check engine indicator lights up.i pull up to the side and shut down the engine and start up again.This time there is no indicator.
Please advise
Old Dec 21, 2001 | 09:40 AM
urbanlegend21's Avatar
New User
Default Re: accord 95 check engine (ashish_bhatta)
have you ever checked what code it is throwing?
Old Dec 21, 2001 | 09:45 AM
Could you please guide me how to check the code?
Thanks
Old Dec 21, 2001 | 10:11 AM
New User
ther should be two blue plugs underneath your glove box, both being female connectors. There should be one with two outlets and one with three outlets.
The one with two is the one you need.
With your ignition on stick a paper clip in the plug to connect the circuit. ( stick one end of the paper clip in one side and the other end in the other side)
you should notice your CEL(check engine light) flashing a sequence, this is your code
there will be a long flash at first, there can be anywhere from 1 to 4 of thesethat is your first number
after the long flash(es) there will be a short flash that will be anywhere from 1 to 9 flashes, this will be your second number
wait and let the code go again, there can be more than one, if it does the same sequence over it is just the one code
the first number will equal a multiple of 10, so 1=10 2=20 3=30 and 4=40.
the second number will equal a single digit, so 1=1 2=2 and so on
these numbers together will equal your code number
this website has further explanations and will tell you the problem for the code
when you find out what it is come nback and we will try to diagnos your problem if you want http://www.eastcoastdelsol.com/columns/view.php?id=9
STR8__
K Series
Mar 7, 2017 08:20 AM
Ankit Poonia
Feb 15, 2015 05:30 AM
halfNhalf-83
Mar 15, 2004 10:00 AM
2qwik2nv
Sep 10, 2002 12:47 PM
